BT.com
Wishlist
NEC Multisync EA274WMi 27" 2560x1440 DVI HDMI DisplayPort USB LED Monitor White
Delivery
Standard Due date unavailable
The 27" NEC MultiSync EA274WMi is a WQHD widescreen LCD for high-performance enterprise users that require advanced technologies and full feature sets. Designed to enhance work performance, this widescreen model features IPS panel technology with wide viewing angles and ergonomic adjustability. The LED backlighting of the EA274WMi allows for a slimmer profile, lighter weight and increased power savings. This model also boasts a height-adjustable stand and full connectivity with DisplayPort, HDMI, DVI-D and VGA inputs. The EA274WMi includes touch-sensitive on screen display controls, a Picture by Picture (PBP) mode for two inputs onscreen at the same time, streamlined cable management and ControlSync technology, which allows users to control up to six units in a multi-monitor configuration.
NEC MultiSync EA274WMI - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
6 ms
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
White
63.92 cm x 23 cm x 41.79 cm
8.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, TCO '06, ERP
3 years warranty
Display Type
Energy Class
Class C
64 kWh
44 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour temperature, off timer
Ambient light sensor, Navi Key, picture by picture, ErgoDesign, Intelligent Power Manager (IPM), sRGB colour management, NaViSet, Eco-Mode, DICOM calibrated, Auto Contrast, ControlSync, Carbon Footprint Meter, Carbon Savings Meter, Human Sensor, Non-Touch-Auto-Adjustment (NTAA)
White
8.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI , DisplayPort , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , USB 3.0 upstream , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x USB cable , 1 x audio cable , 1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x ControlSync cable
Power Supply
Internal
AC 120/230 V
44 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
Scroll to top
