BT.com
Wishlist
NEC Multisync EA273WMi 27" 1920x1080 5ms VGA DVI-D HDMI IPS LED Monitor
NEC Multisync EA273WMi 27"...
£393.04
28 in stock
£393.04
Add to wishlist
Delivery
Standard 1-3 working days
The 27" NEC MultiSync EA273WMi is a widescreen LCD for high-performance enterprise users that require advanced technologies and full feature sets. Designed to enhance work performance, this widescreen model features IPS panel technology with wide viewing angles and ergonomic adjustability. The LED backlighting of the EA273WMi allows for a slimmer profile, lighter weight and increased power savings. This model also boasts a height-adjustable stand and full connectivity with DisplayPort, HDMI, DVI-D and VGA inputs.
NEC MultiSync EA273WMi - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080 at 60 Hz
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
63.93 cm x 23 cm x 41.8 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, ERP, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Infrared user sensor, ambient light sensor, Navi Key, No Touch Auto Adjust, Intelligent Power Manager (IPM), power off timer, cable management cover, sRGB colour management, NaViSet, Eco-Mode, DICOM calibrated, ControlSync, OSD lock, Carbon Footprint Meter, Carbon Savings Meter
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D (HDCP) , HDMI , DisplayPort , VGA , USB 2.0 downstream (Type B) , 4 x USB 2.0 upstream (Type A) , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x ControlSync cable , 1 x USB cable , 1 x audio cable
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
Scroll to top
