BT.com
Wishlist
NEC MultiSync E223W 22" 1680x1050 DVI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
NEC MultiSync E223W features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a perfect feature set for the standard corporate office. The display offers 110 mm height adjustment and a broad connectivity with three inputs DisplayPort, DVI-D and D-Sub.
NEC MultiSync E223W - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:10
Native Resolution
HD 720p 1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
White
50.35 cm x 21.8 cm x 38.4 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, ERP, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A+
25 kWh
17 W
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
Widescreen - 16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 82.3 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
No Touch Auto Adjust, ErgoDesign, Intelligent Power Manager (IPM), power off timer, sRGB colour management, HDCP, NaViSet, Eco-Mode, OSD lock
White
5.6 kg
DVI-D (HDCP) , DisplayPort , VGA
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
25 Watt
Power Consumption Stand by
0.4 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
