BT.com
Wishlist
NEC Multisync E223W  22" Wide Screen LCD (black)  LED Backlights
NEC Multisync E223W 22" Wide...
£184.71
14 in stock
£184.71
Add to wishlist
Delivery
Standard 1-3 working days
NEC MultiSync E223W features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a perfect feature set for the standard corporate office. The display offers 110 mm height adjustment and a broad connectivity with three inputs DisplayPort, DVI-D and D-Sub.
NEC MultiSync E223W - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:10
Native Resolution
HD 720p 1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
50.35 cm x 21.8 cm x 38.4 cm
5.6 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, ERP, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A+
25 kWh
17 W
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
Widescreen - 16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 82.3 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
No Touch Auto Adjust, ErgoDesign, Intelligent Power Manager (IPM), power off timer, sRGB colour management, HDCP, NaViSet, Eco-Mode, OSD lock
5.6 kg
DVI-D (HDCP) , DisplayPort , VGA
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
25 Watt
Power Consumption Stand by
0.4 Watt
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
