BT.com
Wishlist
NEC MultiSync E171M 17" 1280x1024 5ms VGA DVI LED Monitor
NEC MultiSync E171M 17" 1280x1024...
£144.44
40 in stock
£144.44
Add to wishlist
Delivery
Standard 1-3 working days
The E171M is a 17" 5:4 conventional format monitor with latest energy saving LED backlight technology. It offers excellent connectivity with ergonomic adjustability. Low power consumption and low operating costs make the display perfect for use in the professional office environment. Outstanding ergonomic comfort make it very user-friendly and help to increase productivity.
NEC MultiSync E171M - LED monitor - 17"
LED-backlit LCD monitor - 17"
Energy Class
Class A
Energy Consumption per Year
18 kWh
Power Consumption (On mode)
12 W
Stereo speakers
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Height, tilt
36.8 cm x 23 cm x 35.85 cm
4.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, MPR II, CSA, UL, TUV GS, cUL, DDC-2B, DDC-2Bi, MPR III, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, TCO Displays 6.0, EAC
3 years warranty
Display Type
Energy Class
Class A
18 kWh
12 W
Diagonal Size
17"
Viewable Size
17"
Built-in Devices
Stereo speakers
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
31.5 - 81.1 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
170
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour temperature
Rapid Response, OSD lock, Carbon Savings Meter, NaViSet Administrator 2, Non-Touch-Auto-Adjustment (NTAA)
4.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D (HDCP) ¦ VGA (HD-15) ¦ Audio line-in ¦ Headphones
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
50 mm
Flat Panel Mount Interface
100 x 100 mm
Cable management clip
1 x VGA cable ¦ 1 x audio cable
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
19 Watt
On / Off Switch
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - 3 years ¦ Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
Scroll to top
