BT.com
Wishlist
NEC M350X LCD XGA Projector - 3500 ANSI Lumens
Free delivery
Delivery
Standard Due date unavailable
Get great performance while saving the environment. Advanced eco features help to substantially lower your operating cost without compromising on quality and flexibility. The M350X is particularly suited for bigger classrooms and bigger meeting rooms.
NEC M350X LCD projector
LCD projector
Built-in Devices
Speaker
Brightness
3500 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
230 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
302 Watt
33.9 cm x 25.7 cm x 9.9 cm
3 kg
3 years warranty
LCD projector
Built-in Devices
Speaker
Projector
Brightness
3500 lumens
Contrast Ratio
2000:1
Image Size
63.5 cm - 762 cm
Projection Distance
0.6 m - 13.8 m
Throw Ratio
1.3 - 2.2:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
230 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, aspect control
Eco-Mode technology, Colour Management System, freeze frame, Micro Lens Array (MLA) Technology, wall colour correction, Auto Vertical Keystone
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.1
Zoom Type
Manual
Zoom Factor
1.7x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Input Device
External
2 x VGA input - 15 pin D-Sub (DB-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x HDMI , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A
Wireless remote control
1 x VGA cable - 1.8 m
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock, security bar
TUV GS, RoHS, GOST-R, EuP Ready
Nominal Voltage
302 Watt
Power Consumption Operational (Standby)
0.4 Watt
Software Included
Drivers & Utilities
33.9 cm
25.7 cm
9.9 cm
3 kg
EMEA warranty - 3 years , EMEA warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80%
Sound Emission
35 dB
29 dB
Scroll to top
