BT.com
Wishlist
NEC M300WS WXGA Widescreen HD 720p LCD Projector - 3000 ANSI Lumens - Free 5 Year Warranty
Delivery
Standard Due date unavailable
Get great performance while saving the environment. Advanced eco features help to substantially lower your operating cost without compromising on quality and flexibility. Less shadow and glare gives the presenter more space to engage with his audience enhances the experience with interactive white boards. Go wide with your presentations and play video content in native format. The M300WS is particularly suited for classrooms and small to medium sized meeting rooms.
NEC M300WS - LCD projector
LCD projector - High Definition 720p
Built-in Devices
Speaker
Brightness
3000 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
265 Watt
Bulb life cycle
Up to 3500 hour(s) / up to 4000 ns (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
302 Watt
39.8 cm x 31 cm x 14 cm
4 kg
3 years warranty
LCD projector - HD 720p
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Contrast Ratio
2000:1
Image Size
152 cm - 279 cm
Throw Ratio
0.47:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
265 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, aspect control
Eco-Mode technology, Color Management System, freeze frame, Micro Lens Array (MLA) Technology, wall colour correction, Auto Vertical Keystone, Deep Color
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Input Device
External
Lens cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock, security bar
TUV GS, RoHS, GOST-R
Nominal Voltage
302 Watt
Power Consumption Operational (Standby)
0.4 Watt
39.8 cm
31 cm
14 cm
4 kg
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80%
Sound Emission
37 dB
31 dB
Scroll to top
