BT.com
Wishlist
NEC M260XS LCD XGA Projector - 2600 ANSI Lumens
Delivery
Standard Due date unavailable
Get great performance while saving the environment. Advanced eco features help to substantially lower your operating cost without compromising on quality and flexibility. Less shadow and glare gives the presenter more space to engage with his audience and enhances the experience with interactive white boards. The M260XS is particularly suited for classrooms and small to medium sized meeting rooms.
NEC M260XS - LCD projector
LCD projector
Built-in Devices
Speaker
Brightness
2600 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
185 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 480i, 576i, 576p, 1080/60i, 1080/50i
Speakers
Speaker(s) - integrated
239 Watt
39.8 cm x 31 cm x 14 cm
4 kg
3 years warranty
LCD projector
Built-in Devices
Speaker
Projector
Brightness
2600 lumens
Contrast Ratio
2000:1
Image Size
152 cm - 279 cm
Throw Ratio
0.47:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
185 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, aspect control
Color Management System, freeze frame, Micro Lens Array (MLA) Technology, wall colour correction, Auto Vertical Keystone
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Input Device
External
2 x VGA input - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x HDMI input , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A
Lens cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock, security bar
TUV GS, RoHS, GOST-R
Nominal Voltage
239 Watt
Power Consumption Operational (Standby)
0.4 Watt
39.8 cm
31 cm
14 cm
4 kg
EMEA warranty - 3 years , EMEA warranty - lamp - 6 months / 1000 hours
5 °C
20 - 80%
Sound Emission
35 dB
29 dB
Accessories
£231.15
Scroll to top
