BT.com
Wishlist
NEC EA193Mi 19" 1280x1024 DVI VGA DP LED With Speakers
NEC EA193Mi 19" 1280x1024 DVI VGA...
£178.70
15 in stock
£178.70
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The EA193Mi is a high-end 19" 5:4 conventional format monitor with best IPS panel and latest energy saving LED backlight technology. It offers the latest DisplayPort connectivity and full ergonomic adjustability. Low power consumption and low operating costs make the display perfect for use in the professional office environment. Outstanding ergonomic comfort and intelligent features such as the Ambient Light Sensor make it very user-friendly and help to increase productivity.
NEC MultiSync EA193Mi - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class A
Energy Consumption per Year
20 kWh
Power Consumption (On mode)
14 W
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
40.8 cm x 21.39 cm x 38.64 cm
6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, ERP, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A
20 kWh
14 W
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
31.5 - 81.1 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour temperature
Ambient light sensor, No Touch Auto Adjust, ErgoDesign, Intelligent Power Manager (IPM), power off timer, cable management cover, sRGB colour management, HDCP, NaViSet, Eco-Mode, Dynamic Visual Mode, OSD lock, NaViSet Administrator, Carbon Footprint Meter, Carbon Savings Meter, TORO Design
40.8 cm x 21.39 cm x 38.64 cm - with stand
6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D (HDCP) , DisplayPort , VGA (HD-15)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
18 Watt
Power Consumption Stand by
0.35 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 40.8 cm - depth: 6.5 cm - height: 33.8 cm - weight: 4 kg , With stand - width: 40.8 cm - depth: 21.39 cm - height: 38.64 cm - weight: 6 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
Scroll to top
