BT.com
Wishlist
NEC E905 90" 1920x1080 12/7 Usage Edge LED Backlit LFD
NEC E905 90" 1920x1080 12/7 Usage...
£10,726.58
£10,726.58
Add to wishlist
Delivery
Standard 1-3 working days
The NEC MultiSync E905 succeeds in balancing impressive visual performance with a budget-oriented large format presentation without compromise. The 90 inch (229 cm) LCD-panel features a detail-rich Full HD resolution, eye-pleasing black levels for ergonomic viewing and exciting connectivity optimized to the needs of corporate applications. Thanks to an integrated ambient light sensor and LED backlight technology, the model features an amazingly low TCO with maintenance-free operation.
This display is ideal for corporate conferencing and education usage as well as digital signage applications in museums, hospitality and retail environments with operating hours limited to 12/7.
NEC MultiSync E905 E Series - 90" LED display
LED-backlit LCD flat panel display
Diagonal Class
90"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Energy Class
Class A
270 Watt
Power Consumption (On mode)
266 W
Energy Consumption per Year
388 kWh
205.8 cm x 12.3 cm x 118.4 cm
81 kg
3 years warranty
Energy Class
Class A
270 Watt
266 W
388 kWh
Diagonal Class
90"
Commercial Use
Series
E Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Landscape mode, Eco mode
Dimensions
Without stand
205.8 cm
12.3 cm
118.4 cm
81 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
4 ms
Carbon Footprint Meter, automatic alarm e-mails, Point Zoom function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI - rear , USB , Serial input , 2 x audio input , VGA input , DisplayPort input , DVI-D input , HDMI input - side , Network , Audio output , Speakers output
NaViSet Administrator 2
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
Power supply
Power Consumption Stand by
1 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Scroll to top
