BT.com
Wishlist
NEC E805 80" 1920x1080 VGA DVI HDMI DP LED LFD
NEC E805 80" 1920x1080 VGA DVI HDMI...
£5,698.06
£5,698.06
Add to wishlist
Delivery
Standard Due date unavailable
NEC's 80" large screen E805 delivers a cost-effective solution while maintaining high definition and contrast ratios for superior visual quality. The displays are ideal for boardroom, conference room and meeting room environments. The large size also makes it ideal for digital signage applications.
NEC MultiSync E805 E Series - 80" LED display
LED-backlit LCD flat panel display
Diagonal Class
80"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Energy Class
Class A+
430 Watt
Power Consumption (On mode)
139 W
Energy Consumption per Year
203 kWh
183.6 cm x 8.7 cm x 106.1 cm
61 kg
3 years warranty
Energy Class
Class A+
430 Watt
139 W
203 kWh
Diagonal Class
80"
Commercial Use
Series
E Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Landscape mode, Eco mode
Dimensions
Without stand
183.6 cm
8.7 cm
106.1 cm
61 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
4 ms
Carbon Footprint Meter, automatic alarm e-mails, Point Zoom function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI - rear , USB , Serial input , 2 x audio input , VGA input , DisplayPort input , DVI-D input , HDMI input - side , Network , Audio output , Speakers output
NaViSet Administrator 2
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, VESA DPMS, PSB, RoHS
Power supply
Power Consumption Stand by
1 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
20 - 80%
Scroll to top
