BT.com
Wishlist
NEC E654 65" 1920x1080 HDMI LED LFD
NEC E654 65" 1920x1080 HDMI LED...
£2,301.19
£2,301.19
Add to wishlist
Delivery
Standard Due date unavailable
For affordable digital signage applications yet with impressive screen performance, the MultiSync E654 features the edge LED backlight technology for an ultra slim design, light weight and very low power consumption.
NEC MultiSync E654 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/60p, 1080/30p, 480/60i
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
S-PVA
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Energy Class
Class B
260 Watt
Power Consumption (On mode)
208 W
Energy Consumption per Year
304 kWh
146.7 cm x 10 cm x 87.2 cm
30 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class B
260 Watt
208 W
304 kWh
Diagonal Class
65"
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Dimensions
Without stand
146.7 cm
10 cm
87.2 cm
30 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6.5 ms
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
Supported Pictures Formats
JPG
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
VGA input , 3 x HDMI , SPDIF output , Serial , USB , Composite video / component video input , Audio input , Audio input
VGA cable
FCC Class B certified, CSA, UL, C-Tick, cUL, VESA DPMS, VESA FDMI, PSB, RoHS
ENERGY STAR Version
6.0
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years , Limited warranty - backlight - 3 years
10 - 80%
Scroll to top
