BT.com
Wishlist
NEC E585 EDge Black LED Large Format Display 1920 x 1080
NEC E585 EDge Black LED Large...
£1,608.81
More than 50 in stock
£1,608.81
Add to wishlist
Delivery
Standard 1-3 working days
The NEC MultiSync E585 succeeds in balancing impressive visual performance with a budget-oriented large format presentation without compromise. The model captures attention via eye-pleasing image quality for ergonomic viewing and versatile digital connectivity optimized to the needs of corporate and signage applications. Thanks to the LED backlight technology, the display features an amazingly low TCO and maintenance-free operation. Packed with integrated features like USB media player, speakers and scheduling function, E-series models are also qualified for standalone applications in public environments. This display is ideal for corporate conferencing and education usage as well as digital signage applications in museums, hospitality and retail environments with operating hours limited to 12/7.
NEC MultiSync E585 E Series - 58" LED display
LED-backlit LCD flat panel display
Diagonal Class
58"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 120 V (50/60 Hz)
109 Watt
130.1 cm x 10.9 cm x 75.9 cm
11.9 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
109 Watt
Diagonal Class
58"
Commercial Use
Series
E Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Landscape mode, Eco mode
130.1 cm
10.9 cm
75.9 cm
11.9 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
9 ms
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
3 x HDMI , USB , Serial input , Audio input , VGA input , Composite video / component video input , Audio input , Digital audio output (optical)
VGA cable
FCC Class B certified, CSA, UL, C-Tick, cUL, SASO, VESA DPMS, VESA FDMI, PSB, RoHS, REACH, TCO Certified Edge
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
AC 120 V (50/60 Hz)
Power Consumption Stand by
0.5 Watt
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 80%
Scroll to top
