BT.com
Wishlist
NEC E505 50" 1920x1080 VGA HDMI LED Large Format Display
NEC E505 50" 1920x1080 VGA HDMI LED...
£852.61
£852.61
Add to wishlist
Delivery
Standard Due date unavailable
The NEC MultiSync E505 succeeds in balancing impressive visual performance with a budget-oriented large format presentation without compromise. The model captures attention via eye-pleasing image quality for ergonomic viewing and versatile digital connectivity optimized to the needs of corporate and signage applications.
Thanks to LED backlight technology, the display features an amazingly low TCO. Packed with integrated features like USB media player, speakers and scheduling function, E-Series models are also qualified for standalone applications in public environments.
This display is ideal for corporate conferencing and education usage as well as digital signage applications in museums, hospitality and retail environments with operating hours limited to 12/ 7.
NEC MultiSync E505 E Series - 50" LED display
LED-backlit LCD flat panel display
Diagonal Class
50"
Commercial Use
Yes - digital signage / hospitality
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/60p, 1080/30p, 480/60i
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
S-PVA
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A
124 Watt
Power Consumption (On mode)
87 W
Energy Consumption per Year
127 kWh
112.36 cm x 7.7 cm x 64.67 cm
12.62 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class A
124 Watt
87 W
127 kWh
Diagonal Class
50"
Commercial Use
Series
E Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
Modes
Landscape mode
Dimensions
Without stand
112.36 cm
7.7 cm
64.67 cm
12.62 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
5000:1
Brightness
300 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
8 ms
Colour Temperature Control
Scheduler Function (with RTC)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 400 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Audio Controls
Equalizer
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
3 x HDMI - side , USB - side , Serial input - side , Composite video / component video input - rear , Audio input - rear , VGA input - rear , Audio input - rear , SPDIF output - rear
2 AAA batteries
VGA cable
FCC Class B certified, CSA, UL, C-Tick, cUL, DDC-2B, SASO, VESA DPMS, PSB, REACH
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Sleep
0.5 Watt
On / Off Switch
Limited warranty - 3 years , Limited warranty - backlight - 3 years
Dimensions & Weight Details
Panel with stand - 112.36 cm x 25.5 cm x 68.37 cm x 13.12 kg , Panel without stand - 112.36 cm x 7.7 cm x 64.67 cm x 12.62 kg
20 - 80%
Scroll to top
