BT.com
Wishlist
NEC E325 32" 1366x768 HDMI VGA LED Large Format Display
NEC E325 32" 1366x768 HDMI VGA LED...
£391.05
35 in stock
£391.05
Add to wishlist
Delivery
Standard 1-3 working days
The NEC MultiSync E325 succeeds in balancing impressive visual performance with a budget-oriented large format presentation without compromise. The model captures attention via eye-pleasing image quality for ergonomic viewing and versatile digital connectivity optimized to the needs of corporate and signage applications.
Thanks to latest LED backlight technology, the display features an amazingly low TCO and maintenance-free operation. Packed with integrated features like USB media player, speakers and scheduling function, E-Series models are also qualified for standalone applications in public environments.
This display is ideal for education usage as well as digital signage applications in museums, hospitality and retail environments with operating hours limited to 12/ 7.
NEC MultiSync E325 32" LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage / hospitality
Resolution
1366 x 768
Display Format
720p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
S-PVA
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
Speaker System
2 speakers
USB
Remote Control
Standard remote
Energy Class
Class A
Power Consumption (On mode)
36 W
Energy Consumption per Year
53 kWh
72.7 cm x 7.7 cm x 42.4 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class A
36 W
53 kWh
Diagonal Class
32"
Commercial Use
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Landscape mode
Dimensions
Without stand
72.7 cm
7.7 cm
42.4 cm
4.9 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Image Contrast Ratio
3000:1
Brightness
300 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6 ms
Colour Temperature Control
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
100 x 100 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 720, 720 x 400, 1920 x 1080, 1280 x 800
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Equaliser
Speaker System
2 speakers
Output Power / Total
10 Watt
Speakers
2 x main channel speaker - built-in - 5 Watt
Connector Type
VGA input ¦ Composite video / component video input ¦ Audio line-in ¦ 3 x HDMI ¦ SPDIF output ¦ Serial ¦ Audio input ¦ USB
VGA cable
FCC Class B certified, UL, C-Tick, cUL, DDC-1, DDC-2B, SASO, PSB, RoHS
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Power Consumption Stand by
0.5 Watt
On / Off Switch
Limited warranty - 3 years ¦ Limited warranty - backlight - 3 years
10 - 80%
Scroll to top
