BT.com
Wishlist
NEC E224WMIB 21.5" LED 1920X1080 6ms VGA DVI
Sorry but this product has been discontinued.
View used stock
Delivery
Standard Due date unavailable
NEC's 22" MultiSync E224Wi uses a premium-grade IPS panel, which provides wide viewing angles, outstanding color consistency and image accuracy. Its LED backlighting technology allows a thinner, lighter and sleeker design, as well as higher power efficiency. This EPEAT Silver model includes DisplayPort, DVI-D and VGA D-Sub inputs to connect you to the peripherals. Touch-sensitive controls enable simple display adjustments through the E224Wi's On Screen Display (OSD). Enjoy full ergonomic flexibility with height adjustment, tilt, and swivel and portrait adjustability.
NEC MultiSync E224Wi - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
50.74 cm x 21.39 cm x 36.45 cm
5.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, DDC-2B, MPR III, TUV Ergo, PSB, RoHS, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class B
32 kWh
22 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
31.5 - 81.1 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
ErgoDesign, sRGB colour management, Eco-Mode, NaViSet Administrator, Carbon Footprint Meter, Carbon Savings Meter, TORO Design
50.74 cm x 21.39 cm x 36.45 cm - with stand
5.9 kg
DVI-D (HDCP) , DisplayPort , VGA
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), cable organizer
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D
Power Supply
Internal
25 Watt
Power Consumption Stand by
0.4 Watt
Dimensions & Weight Details
Without stand - width: 50.74 cm - depth: 5.85 cm - height: 30.11 cm
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
20 - 80%
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
NEC E224WMIB 21.5
Item condition Customer return - item has been opened but is in excellent condition
Ref: 9YFH 033601
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£45.01
NEC E224WMIB 21.5
Ref: 9YFH 033602
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£45.01
NEC E224WMIB 21.5
Item condition Customer return - item has been used and shows signs of use
Ref: 9YFH 029942
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£23.28
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
