Click to visit BT.com
BT.com
Wishlist
NEC 5500 ANSI Lumens WXGA projector - 7.7kg (PA550W)
Quicklinx: 7N7LWS00
Mfr#: 60003085
NEC's 5500-lumen PA550W is a widescreen, advanced professional installation model that appeases corporate and high education users. With integrated RJ45, high-speed wireless LAN and a multitude of simple-to-use asset management technologies, the PA550W helps users present seamlessly without worrying about their technology. The industry's first built-in stacking correction capabilities allow the projectors to boost an image's brightness up to 22,000 lumens, which is ideal for larger-sized screens and environments with heavy ambient light. This feature also prevents the complete loss of an image, which can happen when using only one projector.
*Lens NOT Included
NEC PA550W LCD projector
LCD projector - High Definition 720p
Built-in Devices
Speaker
Brightness
5500 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
330 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video ( NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60 ) , LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI), DisplayPort
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 576/50i
Speakers
Speaker(s) - integrated
AC 120/230 V ( 50/60 Hz )
443 Watt
49.9 cm x 35.9 cm x 14.4 cm
7.7 kg
3 years warranty
LCD projector - HD 720p
Built-in Devices
Speaker
Projector
Brightness
5500 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 1270 cm
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 108 kHz
Bulb type
330 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Eco-Mode technology, 3D Reform technology, Micro Lens Array (MLA) Technology, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, Hollywood Quality Video (HQV)
Lens
Focus Type
Manual
Zoom Type
Manual
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video, S-Video, RGB
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
Input Device
External
2 x VGA input - 15 pin HD D-Sub (HD-15) , 5 x RGB input - BNC , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x DisplayPort - 20 pin DisplayPort , 1 x S-video input - 4 PIN mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 2 x USB 2.0 - 4 pin USB Type A
Lens cover, wireless remote control
1 x VGA cable
Security Features
Password protection, control panel lock
TUV GS, DDC/CI, RoHS, ErP Ready
Nominal Voltage
443 Watt
Power Consumption Operational (Standby)
0.2 Watt
Software Included
Drivers & Utilities
49.9 cm
35.9 cm
14.4 cm
7.7 kg
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
31 dB
28 dB
