BT.com
Wishlist
NEC 46" Widescreen LCD Display
Delivery
Standard Due date unavailable
With its high-bright, professional-grade panel and remarkable contrast ratio (3500:1), the 46" NEC MultiSync X461HB displays images at amazing brightness levels no matter the lighting condition. Ideal for environments heavy with ambient light, this model boasts 110% higher brightness than NEC's previous-generation displays while consuming only 50% more power. The result is an image that outperforms that of displays with standard brightness, which can appear dim or washed out when placed in areas with high ambient light. The X461HB's unrivaled screen performance is enhanced by 30+ advanced features of the digital signage technology suite, including advanced thermal protection.
NEC MultiSync X461HB 46" LCD flat panel display
Diagonal Class
46"
Resolution
1360 x 768
Display Format
720p
Input Video Formats
480p, 480i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI, S-Video
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
S-PVA
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
XtraView+
Sound Output Mode
Stereo
Speaker System
Speakers not included
Remote Control
Standard remote
Microsoft Certification
Certified for Windows Vista
Voltage
Energy Class
Class G
320 Watt
106 cm x 14 cm x 60.9 cm
31 kg
3 years warranty
Energy Class
Class G
320 Watt
Diagonal Class
46"
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS), temperature sensor
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode
XtraView+
Timer Functions
Countdown
100
Dimensions
Without stand
106 cm
14 cm
60.9 cm
31 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1360 x 768
Display Format
720p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
3500:1
Brightness
1500 cd/m²
Widescreen Modes
16:9
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Pixel Pitch
0.7455 x 0.7455mm
Response Time
8 ms
V-Sync Rate at Max Res.
60 Hz
Max V-Sync Rate
85 Hz
Max H-Sync Rate
91.1 kHz
Eco TV, AmbiBright, AutoBright Technology, NaViSet, Scheduler Function (with RTC), TileMatrix (10 x 10), Digital Signage Technology Suite (DSTS), Rapid Response technology, CableComp, TileComp, TileMatrix
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
Video Features
16:9 Mode
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1440 x 1050, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080
Remote Control
Standard remote
Audio System
Sound Output Mode
Stereo
Speaker System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
RGB input ¦ RGB output ¦ HDMI ¦ DVI-Digital ¦ VGA input ¦ Component video input ¦ Composite video output ¦ Composite video input ¦ S-Video input ¦ Composite video input ¦ 2 x audio line-in ¦ Audio line-in ¦ Audio line-out ¦ 2 x serial ¦ Network ¦ 4 x speakers output
Expansion Slots
1 x Expansion Slot
VGA cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2B, DDC-2Bi, VESA DPMS, CCC, PSB, DDC/CI
Power supply - internal
Nominal Voltage
Power Consumption Stand by / Sleep
1 Watt
On/off timer, energy save
Limited warranty - 3 years
Dimensions & Weight Details
Panel with stand - 106 cm x 35.1 cm x 64.5 cm x 32.9 kg
Scroll to top
