BT.com
Wishlist
NEC 42" Monitor with Thin Bezel - Black
Delivery
Standard 1-3 working days
NEC's 42" V423 high-performance large-screen display utilizes LED backlighting to deliver both environmental and functional benefits for digital signage. The V423's commercial-grade panel is capable of displaying brilliant imagery and capturing the audience's attention. This Full HD model features built-in speakers and an Open Pluggable Specification (OPS)-compliant expansion slot, which future-proofs the display and allows for the seamless integration of a computer or other NEC/third-party component. Because video, RS-232 control and power are passed internally from the display to the computer, additional cabling is not required, thereby simplifying installations. With integrated temperature sensors and fans, this display is ideal in applications that require extended use, including retail stores, restaurants, indoor venues, training facilities and corporate boardrooms.
NEC MultiSync V423 V Series - 42" LED display
LED-backlit LCD flat panel display
Diagonal Class
42"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
S-IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
DICOM Simulated Gamma
Speaker System
2 speakers
Remote Control
Standard remote
Microsoft Certification
Compatible with Windows 7
Voltage
Energy Class
Class B
220 Watt
Power Consumption (On mode)
89 W
Energy Consumption per Year
130 kWh
97.25 cm x 6.83 cm x 56.54 cm
16.8 kg
3 years warranty
Energy Class
Class B
220 Watt
89 W
130 kWh
Diagonal Class
42"
Series
V Series
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode
100
Cooling System
Fanless
Dimensions
Without stand
97.25 cm
6.83 cm
56.54 cm
16.8 kg
Enclosure Colour
Display
LCD Display Technology
S-IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
1300:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Scheduler Function (with RTC), TileMatrix (10 x 10), Open Pluggable Specification slot, Carbon Footprint Meter
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1280 x 960, 1280 x 720, 720 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1280 x 800, 1400 x 1050, 720 x 576
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
External Speakers Amplifier Power (Total)
30 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
DisplayPort input , HDMI input , DVI-D input , DVI-D output , VGA input , Composite video input , Network , Serial input , Serial output , Remote control input , 2 x speakers output , Audio input , Audio output
DVI cable
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, VESA FDMI, PSB, RoHS
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years ¦ Limited warranty - backlight - 3 years
20 - 80%
Scroll to top
