BT.com
Wishlist
NEC 3500 ANSI Lumens WXGA Projector - 3.9kg (P350W)
Delivery
Standard Due date unavailable
Get great picture performance paired with outstanding network features. Advanced Eco features help to lower your operating and service cost. Because of high brightness and excellent installation flexibility the P350W is the best solution for larger meeting rooms and University lecture halls.
NEC P350W LCD projector - 3D
LCD projector - High Definition 720p
3D Capable
Built-in Devices
Speaker
Ethernet, Fast Ethernet
Brightness
3500 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens Shift Direction
Vertical
Bulb type
265 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 3500 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video ( NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60 ) , LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
AC 120/230 V ( 50/60 Hz )
343 Watt
39.8 cm x 29.6 cm x 11.5 cm
3.9 kg
3 years warranty
LCD projector - HD 720p
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Brightness
3500 lumens
Contrast Ratio
2000:1
Image Size
63 cm - 762 cm
Projection Distance
0.7 m - 14.6 m
Throw Ratio
1.3 - 2.2 :1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
265 Watt
Bulb life cycle
Eco-Mode technology, AutoSense technology, Advanced AccuBlend technology, VORTEX Technology Plus, 3D Reform technology, Micro Lens Array (MLA) Technology, wall colour correction, Auto Vertical Keystone, DICOM Simulation Mode, AMX Device Discovery
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.0
Zoom Type
Manual
Zoom Factor
1.7x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Vertical
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 PIN mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) ( management ) , 1 x USB - 4 PIN USB Type B ( management ) , 1 x USB - 4 pin USB Type A , 1 x network - RJ-45 ( management )
Wireless / wired remote control
1 x VGA cable
Security Features
TUV GS, RoHS, EuP Ready
Nominal Voltage
343 Watt
Power Consumption Operational (Standby)
0.4 Watt
39.8 cm
29.6 cm
11.5 cm
3.9 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years , Limited warranty - lamp - 6 months / 1000 hours
Sound Emission
36 dB
30 dB
Scroll to top
