BT.com
Wishlist
NEC - LCD display - TFT - 27" - widescreen - 1920 x 1080
Delivery
Standard Due date unavailable
The NEC MultiSync EA273WM is the flagship model in the NEC MultiSync EA Series and unites excellent display quality, ergonomics with low environmental impact. The NEC MultiSync EA273WM features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a premium feature set for the corporate office use. Ambient Light and Human Sensors enforce the sustainable product concept while offering improved ergonomics with 130 mm height adjustability.
NEC MultiSync EA273WM - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Stereo speakers, USB 2.0 hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
63.1 cm x 23 cm x 41.5 cm
7.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, MPR II, CSA, UL, TUV GS, GOST, cUL, DDC-2B, DDC-2Bi, MPR III, PCT, VESA EDID, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, GEEA, TCO Displays 5.1, ErP Ready
3 years warranty
Display Type
Energy Class
Class B
Diagonal Size
27"
Built-in Devices
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, colour temperature
Infrared user sensor, ambient light sensor, No Touch Auto Adjust, power off timer, cable management cover, sRGB colour management, HDCP, Eco-Mode, ControlSync
7.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DisplayPort , VGA , DVI-D , HDMI , USB 2.0 upstream ( Type B ) , 4 x USB 2.0 downstream , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x VGA cable , 1 x DVI cable , 1 x USB cable , 1 x audio cable , 1 x remote control cable
Power Supply
Internal
AC 120/230 V
26 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Drivers & Utilities
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
5 °C
35 °C
30 - 80%
Scroll to top
