BT.com
Wishlist
MSI Z87-XPOWER S1150 Intel Z87 DDR3 XL-ATX
Delivery
Standard Due date unavailable
Military Class 4 is the next step in high quality components. The DrMOS 4, Hi-c CAP, Super Ferrite Choke and Dark CAP will make sure that your PC runs more stable under extreme conditions.
DrMOS 4 is the next-gen Mosfet which is used to deliver the power for the CPU. MSI DrMOS 4 does not waste much power, stays cool and is more power efficient than other powersaving solutions. Because DrMOS 4 is a 3-in-1 chip it delivers much more power with less components needed. This solution gives you the power to break world records.
With their aluminum core design, Dark CAP's have been a staple in high-end motherboard design and provides lower Equivalent Series Resistance (ESR) as well as its over-10-year lifespan.
A Hi-c CAP is a very small, but super-efficient capacitor. Besides ensuring enough spacing around a CPU socket to install large coolers, it also allows for 93% energy efficiency. Thanks to Hi-c CAP`s MSI motherboards are the most energy efficient in the market.
Super Ferrite Choke uses a Ferrite core that is Super-Permeable. This allows the Super Ferrite Choke to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability.
WHY MSI OVERCLOCKING MOTHERBOARDS
The MSI OVERCLOCKING motherboards are designed based on four principles:
  • Professional overclockers feedback must be integrated
  • Continue MSI's leading position in power efficiency and stability
  • Only use essential OC tools
  • Infuse the DNA of MSI's Lightning graphics cards
CHANGING THE OVERCLOCKING GAME
  • OC Certified
  • Built with Lightning DNA
  • Enhanced components
  • Enhanced power
  • Enhanced thermal design
  • Military Class Components
  • The cleanest extreme PCB
  • Optimized overclocking BIOS
  • OC Essentials
  • DigitALL Power PWM
OC Certified is a military class burn-in test for motherboards. Running Prime95 for over 24 hours with a highly overclocked CPU is already a stressing endeavor, but removing all airflow from the motherboard ensures that only the best motherboards survive. If a motherboard can survive this, it can survive any overclocking situation.
The MSI Z87 XPOWER motherboard is equipped with all the necessary features to make sure you get the most out of your system. From the Enhanced PWM and Thermal Design that give you the best stability to all the easy features that ensure that you don't have to perform a lot of tricks to get great stability in your quest for performance.
Key Features
  • Intel® Z87 Express Chipset
  • Supports 4th Gen Intel® Core™ / Pentium® / Celeron® processors for LGA 1150 socket
  • Supports DDR3-3000(OC) Memory
  • Supports USB 3.0 + SATA 6Gb/s
  • 32 Phase DigitALL Power Design
  • 4-way Multi-GPU: 4-way NVIDIA SLI & AMD CrossFire Support
  • OC Certified: Military Class Burn-in Test Passed
  • Military Class 4: Top Quality & Stability
  • OC Genie 4: Overclock in 1 Second
  • Click BIOS 4: Easily Fine-tune Your System
  • PCI Express Gen 3: World's 1st PCI Express Gen 3 Motherboard Brand
  • Audio Boost: Reward Your Ears with True Quality
  • Killer Ethernet: Kill Your Lag
  • Sound Blaster X-Fi MB3: Amazing Headphone Surround & Gaming Sound Enhancement
  • Lucid Virtu MVP 2.0: Uncompromised Game Response Performance
  • Wi-Fi 802.11n, Bluetooth 4.0, Intel® Wireless Display
MSI Z87 XPOWER - motherboard - XL-ATX - LGA1150 Socket - Z87
Motherboard - XL-ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600
USB / FireWire Ports
8 x USB 3.0 + 2 x USB 2.0 + ( 4 x USB 3.0 + 4 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
802.11b/g/n, Bluetooth, Gigabit Ethernet
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 3000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Killer Gaming E2205
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 5 x PCIe 3.0 x16 ( dual x16 mode; triple: x16, x8, x8 mode; quad: x8 mode ) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 1 x mSATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 2 x HDMI , 1 x PS/2 keyboard / mouse , 8 x USB 3.0 , 1 x DisplayPort , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 6-pin ATX12V connector, 2 x 8-pin ATX12V connectors
BIOS Features
MSI ClickBIOS 4
Hardware Features
Diagnostic LEDs, MSI Direct OC, V-Check Points, Intel Extreme Memory Profile (XMP) support, Super Charger, NVIDIA 4-way SLI Technology Support, AMD 4-way CrossFireX technology support, ESD Protection, OC Certified, Intel Wireless Display (WiDi), DigitALL Power, MSI Military Class IV, OC Genie 4, Lucid Virtu MVP 2.0, MSI OC PCB, Multi BIOS II, MSI Audio Boost, GO2BIOS, MSI Super RAID, 32 Phase Power Design, MSI CeaseFire
2 aerials, Bluetooth / Wi-Fi module
Software Included
Drivers & Utilities, Intel Extreme Tuning Utility, MSI Command Center, Creative Sound Blaster X-Fi MB 3, Killer Network Manager
Plug and Play
34.5 cm
26.4 cm
Scroll to top
