BT.com
Wishlist
MSI Z87-MPOWER-MAX S1150 Intel Z87 DDR3 ATX
Delivery
Standard Due date unavailable
Military Class 4 is the next step in high quality components. The Hi-c CAPs, Super Ferrite Chokes and Dark CAPs will make sure that your PC runs more stable under extreme gaming conditions.
A Hi-c CAP is a very small, but super-efficient capacitor. Besides ensuring enough spacing around a CPU socket to install large coolers, it also allows for 93% energy efficiency. Thanks to Hi-c CAP`s MSI mainboards are the most energy efficient in the market.
With their aluminum core design, Dark CAP's have been a staple in high-end design mainboard designs and provides lower Equivalent Series Resistance (ESR) as well as its over-10-year lifespan.
Super Ferrite Choke uses a Ferrite core that is Super-Permeable. This allows the Super Ferrite Choke to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability.
The core of Military Class 4 is based on the essentials which increases your stability in the worst conditions. The humidity protection and high temperature protection ensure your system can survive each environment, no matter how harsh. The new structure of the PCB limits EMI radiation. On top of that the all the connectors have ESD protection in order to prevent short circuit.
WHY MSI OVERCLOCKING MOTHERBOARDS
The Z87 MPOWER MAX motherboard is designed based on four principles:
  • Professional overclockers feedback must be integrated
  • Continue MSI's leading position in power efficiency and stability
  • Only use essential OC tools
  • Infuse the DNA of MSI's Lightning graphics cards
CHANGING THE OVERCLOCKING GAME
  • OC Certified
  • Built with Lightning DNA
  • Enhanced components
  • Enhanced power
  • Enhanced thermal design - Military Class Components
  • The cleanest extreme PCB
  • Optimized overclocking BIOS
  • OC Essentials
  • DigitALL Power PWM
OC Certified is a military class burn-in test for motherboards. Running Prime95 for over 24 hours with a highly overclocked CPU is already a stressing endeavor, but removing all airflow from the motherboard ensures that only the best motherboards survive. If a motherboard can survive this, it can survive any overclocking situation.
The MSI Z87 MPOWER MAX motherboard is equipped with all the necessary features to make sure you get the most out of your system. From the Enhanced PWM and Thermal Design that give you the best stability to all the easy features that ensure that you don't have to perform a lot of tricks to get great stability in your quest for performance.
Key Features
  • Intel® Z87 Express Chipset
  • Supports 4th Gen Intel® Core™ / Pentium® / Celeron® processors for LGA 1150 socket
  • Supports DDR3-3000(OC) Memory
  • Supports USB 3.0 + SATA 6Gb/s
  • 20 Phase DigitALL Power Design
  • Multi-GPU: NVIDIA SLI & AMD CrossFire Support
  • OC Certified: Military Class Burn-in Test Passed
  • Military Class 4: Top Quality & Stability
  • OC Genie 4: Overclock in 1 Second
  • Click BIOS 4: Easily Fine-tune Your System
  • PCI Express Gen 3: World's 1st PCI Express Gen 3 Motherboard Brand
  • Audio Boost: Reward Your Ears with True Quality
  • Killer Ethernet: Kill Your Lag
  • Sound Blaster Cinema: Realistic Surround Sound Experience
  • Lucid Virtu MVP 2.0: Uncompromised Game Response Performance
  • Wi-Fi 802.11n, Bluetooth 4.0, Intel® Wireless Display
MSI Z87 MPOWER MAX - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600
USB / FireWire Ports
6 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1760 MB
Audio
HD Audio (8-channel)
LAN
802.11b/g/n, Bluetooth, Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
2400 MHz, 2200 MHz, 2000 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2800 MHz, 3000 MHz, 2600 MHz, 2666 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1760 MB
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Killer Gaming E2205
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 3.0 x16 (dual: x8 mode; triple: x8, x4, x4 mode; single card: x16 mode) , 4 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 1 x mSATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
RAID Features
Intel Rapid Storage Technology
1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 6 x USB 3.0 , 1 x DisplayPort , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 2 x HDMI
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 2 x 8-pin ATX12V connectors
BIOS Features
DMI support, MSI ClickBIOS 4
Hardware Features
MSI Direct OC, V-Check Points, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, 20 Phase Power Design, Super Charger, AMD 3-way CrossFireX technology support, Easy Button 3, Intel Wireless Display (WiDi), DigitALL Power, MSI Military Class IV, OC Genie 4, Lucid Virtu MVP 2.0, MSI MPOWER thermal design, MSI OC PCB, Multi BIOS II, MSI Audio Boost, GO2BIOS
I/O back plate, 2 aerials, Bluetooth / Wi-Fi module
Software Included
Drivers & Utilities, Intel Extreme Tuning Utility, MSI Command Center Lite
Plug and Play
30.4 cm
24.4 cm
Scroll to top
