MSI Z87-GD65-GAMING S1150 Intel Z87 DDR3 ATX
Standard Due date unavailable
MSI GAMING motherboards are designed to provide gamers with best-in-class features and technology. Backed by the imposing looks of MSI's Dragon, each motherboard is an engineering masterpiece tailored to gaming perfection.
  • The highest frag and the lowest lag with Killer™ E2200 Game Networking
  • Crystal clear sound with Audio Boost
  • Top quality audio solution with Sound Blaster Cinema
  • Gaming device port
  • Superb graphics with VGA Boost
  • Blazing fast booting with Super RAID
  • Gaming Device Port
  • Military Class 4 Components
  • OC Genie 4 & Click BIOS 4
  • Optimized for multiple graphics cards
  • Supports DDR3-3000 memory for super fast loading
  • Intel® Z87 Express Chipset
  • Supports 4th Gen Intel® Core™ / Pentium® / Celeron® processors for LGA 1150 socket
  • Supports DDR3-3000(OC) Memory
  • USB 3.0 + SATA 6Gb/s
  • Audio Boost: Reward Your Ears with True Quality
  • Killer Ethernet: Kill Your Lag
  • Military Class 4: Top Quality & Stability
  • OC Genie 4: Overclock in 1 Second
  • Click BIOS 4: Easily Fine-tune Your System
  • PCI Express Gen 3: World's 1st PCI Express Gen 3 Motherboard Brand
  • Multi-GPU: NVIDIA SLI & AMD CrossFire Support
  • Sound Blaster Cinema: Realistic Surround Sound Experience
  • Gaming Device Port: Optimized with Triple Gold-plating for High Polling Rate Gaming Devices
  • Total Fan Control: Optimize All Fan Speed As You Wish
  • Lucid Virtu MVP 2.0: Uncompromised Game Response Performance
  • Super Charger: Quickly Charge your iPad/iPhone/smartphones even under S0/S1/S3/S4/S5 mode
The Killer™ E2200 Intelligent Networking Platform is built for maximum networking performance for online games and high-quality streaming media. Featuring Advanced Stream Detect™, Killer E2200 automatically detects and accelerates game traffic ahead of other network traffic for smoother, stutter-free in-game performance and the competitive edge. With this exclusive, automatic traffic prioritization, games and real-time chat get priority over low-level system chatter, giving you the lowest latency for game data on the most controllable network hardware available.
Through the detection and prioritization of gaming traffic you can finally fully utilize your network without fear of being kicked from an on-line game because of high ping. This enables true multi-tasking without manually enabling or disabling applications, updates and installations. Killer networking actually allows you to use your PC 24 hours a day.
Reward your ears with true quality. Get ready for ear-drum shattering sound, with MSI Audio Boost! With Audio Boost we're delivering the highest audio quality so you can enjoy crystal clear sound and music in games.
Because the complete audio circuitry is isolated from other features, you'll enjoy less interference and more stability.
The built-in headphone amplifier allows you to use studio-grade headgear and get the most amazing sound quality out of your gaming PC.
  • Studio level Integrated 600O Headphone amplifier
  • Gold-flashed audio jacks for pure audio signals
  • EMI shielded audio codec
  • High quality audio capacitors
MSI Z87-GD65 GAMING - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7, Xeon E3-1200 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
Max Allocated RAM Size
1760 MB
HD Audio (8-channel)
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 3000 MHz (O.C.)
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
1760 MB
Audio Codec
Realtek ALC1150
High Definition Audio, Sound Blaster Cinema
Network Controller
Killer Gaming E2205
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 3 x PCIe 3.0 x16 ( dual: x8 mode; triple: x8, x4, x4 mode; single card: x16 mode ) , 4 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 1 x mSATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
RAID Features
Intel Rapid Storage Technology
1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 4 x USB 3.0 , 1 x SPDIF out , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x HDMI , 1 x VGA , 1 x DVI-D
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI support, MSI ClickBIOS 4
Hardware Features
NVIDIA SLI Technology Support, V-Check Points, Onboard LED, Super Charger, AMD CrossFireX technology support, Easy Button 3, MSI Military Class IV, Military Class Essentials, OC Genie 4, Lucid Virtu MVP 2.0, Multi BIOS II, MSI Audio Boost, GO2BIOS, MSI Super RAID, MSI VGA Boost
I/O back plate, "Do-Not-Disturb" door hanger, case badge
Software Included
Drivers & Utilities, MSI Command Center
Plug and Play
30.4 cm
24.4 cm
Scroll to top
