BT.com
Wishlist
MSI Z170A-G43 PLUS Intel S1151 DDR4 USB3.1 PCIe SATA3 M.2 ATX
Delivery
Standard Due date unavailable
The PRO Series motherboards fit in any PC. Quality you can trust with top performance and clever business solutions are key aspects of these motherboards. Make your life easier and boost your business with the super stable, reliable and long-lasting PRO Series motherboards.
OC Genie is the world's first built-in hardware overclocking technology on motherboards. With this one-second overclocking option we're giving you even more performance. Just hit the button and your PC gets another adrenalin shot. Delivering up to 20% of free extra performance for the CPU and memory.
MSI EZ debug LED is an easy troubleshooting tool built with 3 LEDs to indicate to CPU/memory/VGA operation every time you boot up your system. Run into trouble? Use the LEDs to easily identify the item causing problems.
MSI Z170A-G43 PLUS - motherboard - ATX - LGA1151 Socket - Z170
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4 unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
2 x USB 3.1 Gen2 + 2 x USB 3.1 Gen1 + 2 x USB 2.0 + (4 x USB 3.1 Gen1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2600 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.)
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (x16/x4 mode) , 3 x PCIe 3.0 x1 , 2 x PCI , 1 x M.2 socket
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x DVI-D , 2 x USB 3.1 Gen2 , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x PS/2 keyboard / mouse , 2 x USB 3.1 Gen1 , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 4 x USB 3.1 Gen1 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS 5
Hardware Features
AMD CrossFireX technology support, MSI Military Class IV, OC Genie 4, 4K Ultra HD ready, MSI Audio Boost, MSI Guard-Pro, Debug LED, Double ESD Protection, MSI VGA Armor, overvoltage protection
Software Included
MSI M-Cloud
30.4 cm
22.4 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* A very good motherboard with plenty of options for the price
Reviewed by Zak Jones on 23/01/2016
Drivers are easy to get through MSI's website or the Live Update 6 application included. No issues with any of my hardware. BIOS is easy to navigate and intuitive to use. Windows 7 installation was easy - just had to enable one setting in the BIOS and go to use USB mouse/keyboard.
5* Wow, what a motherboard!
Reviewed by Hendry Motter on 21/01/2016
This is a great looking motherboard, with an understated colour scheme that blends in perfectly in my NZXT H440 case.
Has six SATA III ports plus one M.2 slot, and two USB 3.1 ports at the rear in addition to two regular USB3.0 and two 2.0 ports.
The M.2 slot supports the new Samsung 950 Pro running at PCI-Express 3.0 x4 speeds - I installed the 512GB version as my boot drive (no problems there with a fresh install of Windows 10 Home) and got speeds of 2344 MB/s read and 1536 MB/s write (CrystalDiskMark scores), way faster than even the four Intel SSDs I have in RAID 0. It also does not steal bandwidth from my video card.
Scroll to top
