BT.com
Wishlist
MSI Radeon R9 390X Gaming 8GB Twin Frozr V FAN DX12 PCI-E 3.0
Delivery
Standard Due date unavailable
With every new generation of GPUs comes more performance. With every new generation of MSI TWIN FROZR we give you less noise and heat!
  • TWIN FROZR V Thermal Design – 18 months in the development to ensure the cards have the quality and stability to give you the FPS you need.
  • TORX Fan Blades – Maximizes downwards airflow and air dispersion to the massive heatsink below.
  • Airflow Control Technology – Guides more airflow directly onto the heatpipes by using special deflectors on the heatsink.
  • SuperSU Pipe Architecture – A massive nickel-plated copper base plate connected to 8mm heatpipes on the Graphics Card.
  • ZERO FROZR Technology – Eliminates fan noise in low-load situations by stopping the fans when they are not needed.
  • Independent Fan Control Software – The two fans can work independently of each other.
  • Premium White LED Controllable Lighting – Allows you to choose from 5 unique modes to set the right ambience for your gaming moments.
  • MSI Afterburner GPU Overclocking Tool – The world’s favourite cross-vendor GPU overclocking software.
  • MSI GAMING APP – Overclocking through this app is covered by warranty to take away your worries.
TWIN FROZR V
Cooler, Quieter, Better Gaming
We’ve listened to all your requests and the new TWIN FROZR V is smaller, features stronger fans, generates less noise, keeps your graphics card and its components cooler and matches perfectly with your MSI GAMING motherboard including some funky LED lightning. Our new TORX fans generates more airflow to maximize air dissipation to heatsink, while the advanced dispersion blade design generates 19% more airflow without increasing drag for supreme silent performance.
AIRFLOW CONTROL
Enhanced Dissipation Efficiency
MSI has fitted TWIN FROZR V coolers with the all new Airflow Control technology which guides more airflow directly onto the heat pipes by using special deflectors on the heat sink. In addition, this exclusive heat sink design increases heat sink surface area, greatly enhancing the dissipation efficiency.
SuperSU PIPE
SuperSU Architecture is the best cooling solution for graphics cards. The GPU is cooled by a massive nickel-plated copper base plate connected to Super Pipes (8mm heat pipes) on the MSI GAMING series graphics card. Additionally, the new heat pipe layout increases efficiency by reducing the length of unused heat pipe and a special SU-form design.
ZERO FROZR
Smart Cooling, Stay Quiet
MSI’s TWIN FROZR V Thermal Designs are equipped with Zero Frozr technology which was first introduced by MSI back in 2008. Zero Frozr technology eliminates fan noise in low-load situations by stopping the fans when they are not needed. Compared to other graphics cards, there is no continuous hum of airflow to tell you there’s a powerful graphics card in your gaming rig. This means you can focus on gaming without the distraction of other sounds coming from your PC.
INDEPENDENT FAN CONTROL
Maximum Fan Control, Minimum Noise
The two fans on the TWIN FROZR V Thermal Design can work independently of each other. This means you’ll only have the necessary fan noise given the temperature of the components below the fan. This unique solution gives you the best balance between temperatures and noise and highlights why the MSI TWIN FROZR V is seen as the ultimate Graphics Card cooling solution.
Availability of this feature varies by model.
CATCHING THE VIBE WITH COOL LED EFFECTS
White LED Lighting
Featuring a premium LED illuminated MSI GAMING Dragon to lighten the mood. This brand new function allows you to choose from 5 unique modes to set the right ambience for your gaming moments with just one click using the MSI GAMING APP or control it from the NVIDIA GeForce Experience software.
Graphics Processing Unit (GPU)AMD Radeon R9 390X
Interface (Bus Standard)PCI-Express x16 3.0
Core Clock Speed (MHz)1100 Core (OC Mode)
1080 Core (Gaming Mode)
1050 Core (Silent Mode)
Memory Size (MB)8192
Memory TypeGDDR5
Memory Interface512 bits
Memory Clock Speed (MHz)6100
D-Sub (VGA) ConnectorsN/A
DVI Connectors2 (Dual-link DVI-D), Max Resolution: 2560x1600 @60Hz
HDMI Connectors1 (Version 1.4a), Max Resolution: 4096x2160 @24Hz (1.4a)
DisplayPort 1 (Version 1.2), Max Resolution: 4096x2160 @60Hz
Maximum Displays3
HDCP SupportYES
DirectX Version Support12
OpenGL Version Support4.4
Multi-GPU TechnologyCrossFire, Up to 4-Way
Card Dimension (mm)277 x 129 x 51
Power consumption (Watts)275
Recommended PSU (Watt)750
Power Connectors (PCI-e)1x 8-pin, 1x 6-pin
Accessories1x 6-pin to 8-pin Power Cable
MSI R9 390X GAMING 8G graphics card - Radeon R9 390X - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 390X
8 GB GDDR5
Core Clock
1100 MHz
Stream Processors
2816
Effective Memory Clock
6.1 GHz
RAMDAC
400 MHz
Memory Interface
512-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
Max Monitors Supported
3
2 x DVI-D (dual link) , HDMI , DisplayPort
API Supported
OpenGL 4.4, DirectX 12
5.1 cm x 27.7 cm x 12.9 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 390X
Core Clock
1100 MHz
Stream Processors
2816
RAMDAC
400 MHz
Max Resolution
4096 x 2160
3
API Supported
MSI SuperPipe Technology, MSI Solid Capacitor, AMD Eyefinity Technology, AMD HD3D Technology, Dual Fan Design, AMD CrossFireX Technology, AMD PowerTune technology, MSI Afterburner, MSI Gaming App, Military Class 4 Components, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, Twin Frozr V Thermal Design, Torx Fans, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, HDCP
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
6.1 GHz
Bus Width
512-bit
Required Power Supply
400 W
Additional Requirements
6-pin + 8-pin power connectors
275 Watt
6 pin power cable
Software Included
MSI Afterburner, display drivers, MSI Predator
MIL-STD-810G
5.1 cm
27.7 cm
12.9 cm
1.312 kg
Scroll to top
