BT.com
Wishlist
MSI NVIDIA GeForce GT 730 1GB 1006MHz 5000MHz 64-bit DDR5
Delivery
Standard Due date unavailable
Low Profile Design
  • Low profile design saves more spaces.
  • User can build slim or smaller system easier.
All Solid Capacitors
  • 10 years ultra-long lifetime (under full load).
  • Lower temperature and higher efficiency.
  • Extreme low ESR.
Afterburner Overclocking Utility
  • Support in-game video recording.
  • Support wireless control by android/iOS handheld devices.
  • Support built-in DX11 effect test.
3DVision Ready
  • Support for NVIDIA 3D Vision,bringing a fully immersive stereoscopic 3D experience to the PC.
MSI N730K-1GD5LP/OCV1 - graphics card - GF GT 730 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
1 GB GDDR5
Core Clock
1006 MHz
Effective Memory Clock
5 GHz
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 / HDMI: 4096 x 2160
Max Monitors Supported
2
HDMI , DVI-D (dual link) , VGA
API Supported
OpenGL 4.4, DirectX 12
2 cm x 14.5 cm x 6.9 cm
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
1006 MHz
RAMDAC
400 MHz
Max Resolution
4096 x 2160 at 60 Hz
2
API Supported
MSI Solid Capacitor, Nvidia 3D Vision technology, MSI Afterburner, HDCP
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5 GHz
Bus Width
64-bit
Required Power Supply
300 W
30 Watt
Software Included
Drivers & Utilities, Adobe Acrobat Reader, MSI Live Update Series, Norton Internet Security (60 days trial)
2 cm
14.5 cm
6.9 cm
140 g
Scroll to top
