BT.com
Wishlist
MSI H97M ECO 1150 Intel H97 DDR3 M-ATX
Delivery
Standard 3-5 working days
MSI uses unique techniques in hardware and software design for ECO series to use up less power than a light bulb! Save up to 40%. MSI ECO motherboards optimize your power consumption via exclusive technology without losing performance.
With specially designed circuit protection, the MSI motherboard protects the CPU against overheating and USB devices from short circuiting.
MSI H97M ECO - motherboard - micro ATX - LGA1150 Socket - H97
Motherboard - micro ATX
Chipset Type
Intel H97 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1760 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H97 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
1760 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Intel I218V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard , 1 x HDMI , 1 x PS/2 mouse , 1 x DVI-D , 2 x USB 3.0 , 4 x USB 2.0 , 1 x VGA , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x LAN (Gigabit Ethernet)
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI support, M-Flash, MSI ClickBIOS 4
Hardware Features
Intel Smart Response Technology, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel Small Business Advantage support, MSI Military Class IV, MSI Fast Boot, MSI Guard-Pro, ECO Tech Design, ECO button
Software Included
MSI Live Update 6, MSI ECO Center Pro
Plug and Play
24.4 cm
23.5 cm
Scroll to top
