MSI H87M-G43 S1150 Intel H87 DDR3 mATX
Standard Due date unavailable
MSI's new Military Class 4 components support you while you are questing, racing, battling and shooting your way to the top. MSI's Military Class 4 components deliver record-breaking stability when you need to keep cool in the heat of battle. The new standard in stability built on a proven technology of high quality components.
The core of Military Class 4 is based on the essentials which increase your stability in the worst conditions. The humidity protection and high temperature protection ensure your system surviving each environment, no matter how harsh. The new structure of the PCB limits EMI radiation. On top of that all the connectors have ESD protection in order to prevent short circuit.
OC Genie 4
OC Genie 4 supercharges your speed experience! When used, OC Genie 4 accelerates your entire system and puts it into overdrive! Tuned by the professional overclockers, OC Genie 4 hands you record-breaking performance on a silver plate.
Click BIOS 4
The MSI Click BIOS 4 is the latest UEFI BIOS with optimizations for Windows 8. Not only reacting faster and running smoother, it also has better mouse support. This is all comes with many cool features, such as Hardware Monitor, Board Explorer, and OC Profile Preview.
  • Optimizations for Latest Windows
  • Hardware Monitor
  • Board Explorer
  • OC Profile Preview
Key Features
  • Intel® H87 Express Chipset
  • Supports 4th Gen Intel® Core™/Pentium®/Celeron® processors for LGA 1150 socket
  • Supports DDR3-1600 Memory
  • USB 3.0 + SATA 6Gb/s
  • Military Class 4: Top Quality & Stability
  • Military Class Essentials: Total Protection for Military Class Motherboards
  • OC Genie 4: Overclock in 1 Second
  • Click BIOS 4: Easily Fine-tune Your System
  • 4K UHD Support: Ultra-high Definition Visual Experience
  • 4 Display Outputs: DisplayPort/HDMI/DVI/D-Sub Support
  • PCI Express Gen 3: World's 1st PCI Express Gen 3 Motherboard Brand
  • Multi-GPU: AMD CrossFire Support
  • Command Center: Control & Customize Your PC Settings
  • Fast Boot: Quickly Boot Up & Enter OS in A Few Seconds
  • Super RAID: Easily Setup & Configure Intel® Technologies
  • Intel® Small Business Advantage 2.0: Streamiline PC Maintenance & Security
MSI H87M-G43 - motherboard - micro ATX - LGA1150 Socket - H87
Motherboard - micro ATX
Chipset Type
Intel H87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7, Xeon E3-1200 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC , unbuffered
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
HD Audio (8-channel)
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Registered or Buffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio Codec
Realtek ALC892
High Definition Audio
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 ( x4 mode ) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Rapid Storage Technology
1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 2 x USB 3.0 , 1 x DisplayPort , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x microphone - mini-jack , 1 x HDMI , 1 x VGA , 1 x DVI-D
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI support, MSI ClickBIOS 4
Hardware Features
Intel Extreme Memory Profile (XMP) support, Super Charger, Intel Smart Response Technology, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, MSI Military Class IV, Military Class Essentials, OC Genie 4, Intel Small Business Advantage 2.0 support, MSI Fast Boot, 4K Ultra HD ready, MSI Super RAID
Software Included
Drivers & Utilities, MSI Command Center
Plug and Play
24.4 cm
24.4 cm
Scroll to top
