BT.com
Wishlist
MSI H81M PRO-VD Intel S1150 DDR3 USB3.0 PCIe SATA3 uATX
MSI H81M PRO-VD Intel S1150 DDR3...
£47.68
29 in stock
£47.68
Add to wishlist
Delivery
Standard 3-5 working days
Military Class 4 is the next step in high quality components. The Dark Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions.
Dark Choke uses the special core design and allows the Dark Choke to run at a lower temperature with higher capacity and better power efficiency and stability.
With their aluminum core design and Japanese made quality, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year.
MSI H81M PRO-VD - motherboard - micro ATX - LGA1150 Socket - H81
Motherboard - micro ATX
Chipset Type
Intel H81 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600, 2 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H81 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x USB 3.0 , 1 x DVI-D , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x VGA
Internal Interfaces
4 x USB 2.0 - header , 1 x audio - header , 2 x USB 3.0 - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI support, M-Flash, MSI ClickBIOS 4
Hardware Features
Intel Smart Connect Technology, MSI Military Class IV, Military Class Essentials, OC Genie 4, MSI Fast Boot, Clear CMOS Button
Software Included
MSI Command Center, MSI Live Update 6
Plug and Play
23.1 cm
17.3 cm
MSI H81M PRO-VD Intel S1150 DDR3 USB3.0 PCIe SATA3...
£47.68
Save on this ideal PC Build kit!
Save £16.94
£73.06
Scroll to top
