BT.com
Wishlist
MSI H81M-E34 Motherboard LGA 1150 Intel H81 DDR3 VGA DVI USB
Delivery
Standard Due date unavailable
The core of Military Class 4 is based on the essentials which increase your stability in the worst conditions. The humidity protection and high temperature protection ensure your system surviving each environment, no matter how harsh. The new structure of the PCB limits EMI radiation. On top of that all the connectors have ESD protection in order to prevent short circuit.
MSI H81M-E34 - motherboard - micro ATX - LGA1150 Socket - H81
Motherboard - micro ATX
Chipset Type
Intel H81 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600, 2 x SATA-300
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H81 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x PS/2 keyboard / mouse , 2 x USB 2.0 , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x HDMI , 1 x DVI-D
Internal Interfaces
4 x USB 2.0 - header , 1 x serial - header , 1 x audio - header , 2 x USB 3.0 - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, Multilingual BIOS, M-Flash, UEFI BIOS, SMBIOS 2.7 support, ACPI 5.0 support, MSI ClickBIOS 4
Hardware Features
Intel Smart Connect Technology, MSI Military Class IV, Military Class Essentials, OC Genie 4, MSI Fast Boot, 4K Ultra HD ready, Clear CMOS Button
Software Included
MSI Live Update 5, MSI Command Center
Plug and Play, ACPI 5.0
22.6 cm
17.3 cm
Scroll to top
