BT.com
Wishlist
MSI GeForce GTX 770 2GB PCI-E 3.0 HDMI Twin Frozr OC
Delivery
Standard Due date unavailable
  • Marketing name MSI GeForce GTX 770 Gaming
  • Model name N770 TF 2GD5/OC
  • Core Clock /Boost Basic mode: 1059/1098
  • Gaming mode: 1111/1150
  • Memory Clock 7010
  • Memory Size 2050MB
  • Cooling Twin Frozr IV
  • Output(native IO) HDMI Y
  • DVI-I
  • (Dual Link) Y
  • DisplayPort Y
  • Memory Spec. Memory Type GDDR5 (64Mx32bit)
  • Memory Bus 256bit
  • Other Spec. Card Bus PCI-E 3.2
  • DX version DX13
  • Form Factor ATX
MSI N770 TF 2GD5/OC - graphics card - GF GTX 770 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 770
2 GB GDDR5
Core Clock
1098 MHz
Boost Clock
1150 MHz
CUDA Cores
1536
Effective Memory Clock
7.01 GHz
Memory Interface
256-bit
DisplayPort , HDMI , DVI-I (dual link) , DVI-D (dual link) , VGA - with adapter
API Supported
DirectX 11.1, OpenGL 4.3
3.8 cm x 26 cm x 12.6 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1098 MHz
Boost Clock
1150 MHz
CUDA Cores
1536
API Supported
Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Propeller Blade Technology, Twin Frozr IV Thermal Design, MSI Gaming App, Military Class 4 Components
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
256-bit
250 Watt
2 x 8 pin power cables
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, MSI Afterburner, MSI Predator
MIL-STD-810G
3.8 cm
26 cm
12.6 cm
Resources
The following resources are available for the MSI GeForce GTX 770 2GB PCI-E 3.0 HDMI Twin Frozr OC
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Awesome Graphics card
Reviewed by Rameses10 on 18/06/2014
Ordered this version of the GTX770 after carefully consideration and very glad I did.
Installation was very simple and the set up extremely easy, having an MSI mb meant less work to do.
The actual performance of the card is awesome and has brought new life to games.
One thing to note though, it can chuck out a lot of heat when playing on ultra and you may need to upgrade your cooling.
4* Blistering Performance
Reviewed by Nug on 03/09/2014
The MSi Twin Frozr 770GTX can run any game you can throw at it right now (Sep 2014) at 1920x1200 without much trouble at all. 90% of my games run on max settings with a smooth and fluid frame rate.
The only thing I was surprised at was the temps, my card runs at around 75 degrees Centigrade when in full use – compare that to my old ASUS GTX 570 Direct CU II which ran at 55-60 degrees.
Apart from the slightly high temps, I can't find anything bad about it. Excellent Nvidia drivers and now the ability to record in-game without using Fraps.
4/5. Recommended!
Scroll to top
