BT.com
Wishlist
MSI GeForce GTX 680 1006MHz 2GB PCI-Express 3.0 HDMI
Delivery
Standard Due date unavailable
The GeForce GTX 680 graphics card is outfitted with the latest GPU that not only meets PCI Express 3.0 standards and supports DirectX 11 technology, but also features NVIDIA's GPU Boost technology. GPU Boost technology allows the core clock to be automatically adjusted on the fly for optimal performance. When used with the MSI Afterburner overclocking utility, the power limit and clock offset can be adjusted as well for better overclocking capability. A single card can also support NVIDIA 3DVision Surround technology for up to four monitors to give gamers the best visual experience.
Support for MSI's Exclusive Afterburner Overclocking Utility
The MSI GeForce GTX 680 graphics card supports NVIDIA's GPU Boost technology that allows the core clock to be adjusted on the fly for optimal performance. When used with MSI's exclusive Afterburner overclocking utility, gamers can control the power limit and clock offset for better overclocking capability. The card is also equipped with advanced fanspeed control based on GPU temperature. Afterburner comes with MSI Predator Audio/Video capturing function and you can even use smart phones to control the graphics card. When combined with the Kombustor burn-in testing function, it is an indispensable tool for enthusiasts looking to get the most out of their graphics card.
28nm Process and Support for PCI Express Gen 3 Standard
The MSI GeForce GTX 680 graphics card uses the 28nm GeForce GTX 680 GPU and supports the latest PCI Express Gen 3 standards. This advanced manufacturing technology reduces operating temperatures and improves performance, and when combined with the latest connectivity standard it can also deliver a staggering 32GB/s of bandwidth with compatible CPUs and mainboards. For gamers, this means an even better experience with 40% more performance than previous generation GeForce GTX 580 graphics cards.
Support for Single-Card 3DVision Surround Technology
Apart from supporting the latest DirectX 11 technology, the MSI GeForce GTX 680 graphics cards has the ability to run NVIDIA 3DVision Surround using three 3D monitors and 3D glasses with just a single card. Gamers will be able to enjoy the spectacular visuals of 3D games and movies. Additionally, support for up to four displays driven by one graphics card allows gamers to make the most of multiple-monitor configurations.
N680GTX-PM2D2GD5 Technical specifications
  • Product name N680GTX-PM2D2GD5
  • GPU NVIDIA GEFORCE GTX 680
  • GPU Specifications GK104 - 1006 MHz Base Clock 1058 MHz GPUBoost clock
  • Memory 2048MB GDDR5 - 6008 MHz
  • Connectivity DL-DVI-I / DL-DVI-D / DisplayPort / HDMI
  • TDP 195W
  • Overclock Afterburner GPU / Memory Clock offset and Power Limit control
  • Dimensions 270x112x39mm
MSI N680GTX-PM2D2GD5 - graphics card - GF GTX 680 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 680
2 GB GDDR5
Core Clock
1006 MHz
CUDA Cores
1536
Effective Memory Clock
3.004 GHz
Memory Interface
256-bit
DisplayPort , HDMI , DVI-I (dual link) , DVI-D (dual link) , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.2
3.9 cm x 27 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1006 MHz
CUDA Cores
1536
Process Technology
28 nm
API Supported
MSI Solid Capacitor, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Nvidia SLI ready, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
3.004 GHz
Bus Width
256-bit
Additional Requirements
Two 6-pin power connectors
195 Watt
2 x 6 pin power cables
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, MSI Afterburner
3.9 cm
27 cm
11.1 cm
Scroll to top
