BT.com
Wishlist
MSI GeForce GTX 670 1019MHz 2GB PCI-Express 3.0 HDMI OC
Delivery
Standard Due date unavailable
The GTX 670 Power Edition is based on the MSI Power Edition architecture which incorporates triple overvoltage, a strengthened PWM enabling an impressive 22.5% boost in overclocking potential compared to the reference design. The Twin Frozr IV thermal design keeps the card cool and MSI's exclusive Dust Removal technology ensures that the cooling module remains free of dust for optimal cooling performance. In addition, Propeller Blade technology offers 20% more air flow than conventional fans, effectively reducing temperatures by up to 20 °C and noise levels by 11.7 dB. The MSI GTX 670 Power Edition uses military class III components that give overclockers a level of quality and stability they can count on. The power, cooling, and other components of the MSI GTX 670 Power Edition incorporate more functions and technologies than the reference board, making it the choice of those looking for superior overclocking performance.
MSI N670GTX PE 2GD5/OC graphics card - GF GTX 670 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 670
2 GB GDDR5
Core Clock
1019 MHz
Boost Clock
1079 MHz
Effective Memory Clock
6.008 GHz
RAMDAC
400 MHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenGL 4.2
3.8 cm x 26.7 cm x 11.7 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1019 MHz
Boost Clock
1079 MHz
RAMDAC
400 MHz
Max Resolution
2560 x 1600
API Supported
MSI Solid Capacitor, Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Triple Over Voltage, Dual Fan Design, Nvidia SLI ready, Dust Removal Technology, MSI Afterburner, Military Class III Components, Twin Frozr IV Thermal Design, Enhanced PWM Design , HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
6 pin power cable
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Live, MSI Afterburner, MSI StarOSD, MSI Dual Core Center, Norton Internet Security 2008 (60 days trial), MSI Live Update 5
RoHS
3.8 cm
26.7 cm
11.7 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* TOP DOG GTX 670
Reviewed by Tazman on 13/02/2013
I previously had the ASUS HD7970 Matrix Platinum but sent it back and got this MSI GTX 670 card instead.
This GTX 670 card blows the HD 7970 away. I am running this at stock settings and run games to max settings and get what i wanted from a graphics card.
Bench testing between both cards is marginal but the GTX 670 comes out on top.
FPS are also higher on the GTX 670 by 10 - 30 depending on the games played.
On Battlefield 3 running max rez i get around 25 FPS more than the HD7970.
On benchtest using Heaven i had FPS of 109.5 and a score of 2758.
This is actually better than what CustomPC tested at. There score was 1732 which is much lower.
In the past i have always had Radeon graphic cards but decided to try an Nvidia card and I am very impressed with this card.
The MSI Afterburner is my only gripe, as it doesnt register the GPU clock abut shows it at zero so for overclocking you cant tell how much higher you can go.
My solution to this is get ASUS GPU TWEAK. This works very well
5* TOP DOG GTX 670
I previously had the ASUS HD7970 Matrix Platinum but sent it back and got this MSI GTX 670 card instead. This GTX 670 card blows the HD 7970 away. I am running this at stock settings and run games to max settings and get what i wanted from a graphics card. Bench testing between both cards is marginal but the GTX 670 comes out on top. FPS are also higher on the GTX 670 by 10 - 30 depending on the games played. On Battlefield 3 running max rez i get around 25 FPS more than the HD7970. On benchtest using Heaven i had FPS of 109.5 and a score of 2758. This is actually better than what CustomPC tested at. There score was 1732 which is much lower. In the past i have always had Radeon graphic cards but decided to try an Nvidia card and I am very impressed with this card. The MSI Afterburner is my only gripe, as it doesnt register the GPU clock but shows it at zero so for overclocking you cant tell how much higher you can go. My solution to this is get ASUS GPU TWEAK. This works very well
Scroll to top
