BT.com
Wishlist
MSI GeForce GTX 660 1033MHz 2GB PCI-Express 3.0 HDMI OC
Delivery
Standard Due date unavailable
Cooling the way to performance: Better cooling, better performance
MSI is happy to announce the availability of NVIDIA's latest GPU the GEFORCE GTX 660 The new MSI GTX 660 Twin Frozr 2GD5/OC introduce NVIDIA's 28nm GPUs to the crowd looking for a great price/performance ratio in their products. You can find MSI's Twin Frozr III on the MSI GTX 660 Twin Frozr 2GD5/OC where it promises to reduce GPU temperature up to 25% and noise by almost one third.
Afterburner - raise your performance
MSI Afterburner is the de-facto standard overclocking software for enthusiasts and media around the world. When equiped with enhanced Thermal Designs like the Twin Frozr III the overclocking potential is simply higher.
Propeller Blade technology
Twin Frozr coolers are equipped with MSI's patented Propeller Blade technology. The fans feature unique air channels on the fan edges to boost cooling performance by increasing the cooling area and providing 20% more airflow compared to conventional fans. This reduces temperatures and fan noise leading to a comfortable experience, no matter if you're browsing the web, watching a movie or playing the latest games.
Technical specifications
  • Name N660 TF 2GD5/OC
  • GPU NVIDIA GeForce GTX 660
  • Codename GK106
  • CUDA Cores 960
  • Core/Boost Clock 1033/1098
  • Memory 2GB GDDR5 @ 6008 MHz
  • Output DP / HDMI / DL-DVI-I / DL-DVI-D
  • TDP 150w
MSI N660 TF 2GD5/OC graphics card - GF GTX 660 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1033 MHz
Boost Clock
1098 MHz
CUDA Cores
960
Effective Memory Clock
6.008 GHz
Memory Interface
192-bit
Max Monitors Supported
4
DisplayPort ¦ HDMI ¦ DVI-I (dual link) ¦ DVI-D (dual link) ¦ VGA - with adapter
API Supported
DirectX 11, OpenGL 4.2
3.58 cm x 23.5 cm x 12.52 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1033 MHz
Boost Clock
1098 MHz
CUDA Cores
960
4
API Supported
MSI SuperPipe Technology, MSI Solid Capacitor, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Nvidia 2-way SLI ready, Twin Frozr III Thermal Design, Propeller Blade Technology, dual 8CM PWM fans , HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
192-bit
150 Watt
6 pin PCIe power cable
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, MSI Afterburner
3.58 cm
23.5 cm
12.52 cm
Resources
The following resources are available for the MSI GeForce GTX 660 1033MHz 2GB PCI-Express 3.0 HDMI OC
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* High Performance with Reliability
Reviewed by Sam on 21/09/2012
I bought this card after having a nightmare with the Radeon 7870 which was causing a well known problem with lock ups and black screens. This GTX 660 trades blows with the 7870 in terms of performance but it's rock solid in reliability and comes at a cheaper price. This MSI offering comes with a 1098mhz boost clock, which I've overclocked with a +78 GPU and +250 memory offset at 110% power. This runs stable with the core topping out at 1228mhz in games. Voltage is at default since GPU boost handles this; if you force a higher voltage it actually hurts your overclock as GPU boost struggles to keep within the 110% power limit. Very happy with this purchase and I would recommend this card to anyone looking to upgrade from an older generation or wanting to replace the nightmare that can be the 7870 if you're one of the unlucky ones affected by the black screen issue.
5* MSI GeForce GTX 660 1033MHz 2GB PCI-Express 3.0 HDMI OC
Reviewed by Anonymous on 21/02/2013
Very happy with this card. Works perfectly and so far it has coped with everything I have chucked at it on high-max settings at 1920x1080 resolution. The Twin Frozr fans work very well with my idle GPU temp around 30c and even after heavy use it barely goes over 60c. All in all for the money I couldn't recommend this card more, it's a bargain.
Scroll to top
