BT.com
Wishlist
MSI AMD FM2+ A68H DDR3 USB 3.0 GBE LAN DVI VGA
MSI AMD FM2+ A68H DDR3 USB 3.0 GBE...
£41.86
35 in stock
£41.86
Add to wishlist
Delivery
Standard 3-5 working days
Military Class 4 is the next step in high quality components. The Super Ferrite Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions.
Super Ferrite Chokes use a Ferrite core that is Super-Permeable. This allows the Super Ferrite Chokes to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability.
With their aluminum core design and quality, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year.
No more seamless waiting for your O/S to be loaded! MSI Fast Boot helps to make your system boot lightning fast. MSI Fast Boot also features a GO2BIOS button. Simply click it to restart your PC and go straight to the system BIOS.
Compared to the 480Mbps provided by traditional USB 2.0, the USB 3.0's 5Gb/s offers 10 times the transfer bandwidth, so transferring a Blu-ray movie takes less than one minute.
MSI A68HM-P33 V2 - motherboard - micro ATX - Socket FM2+ - AMD A68H
Motherboard - micro ATX
Chipset Type
AMD A68H
Processor Socket
1 x Socket FM2+
Compatible Processors
Athlon, A series
Max RAM Size
32 GB
RAM Supported
2 DIMM slots non-ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 2 x USB 2.0 + (4 x USB 2.0 via headers)
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD A68H
Processor Socket
Socket FM2+
Max Processors Qty
1
Athlon, A series
Supported RAM
Max Size
32 GB
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe x1 , 1 x PCI (3.3 V/ 5 V)
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10
1 x PS/2 keyboard , 2 x USB 3.0 , 1 x VGA , 1 x DVI , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse
Internal Interfaces
1 x audio - header , 4 x USB 2.0 - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
M-Flash, UEFI BIOS, MSI ClickBIOS 4
Hardware Features
AMD Cool 'n' Quiet Technology, USB Safeguard, All-Solid Capacitor motherboard Design, Intel Extreme Memory Profile (XMP) support, MSI Winki 3, AMD Radeon Dual Graphics, Super Ferrite Choke (SFC), AMD Memory Profile (AMP) support, MSI Military Class IV, Military Class Essentials, MSI Fast Boot
Software Included
MSI Live Update 6
22.6 cm
17.3 cm
£41.86
Save on this ideal PC Build kit!
Save £10.36
£61.41
Scroll to top
