BT.com
Wishlist
Motorola AP 7532 Dual Radio 802.11AC 3X3:3 MIMO Access Point
Motorola AP 7532 Dual Radio...
£409.12
£409.12
Add to wishlist
Delivery
Standard Due date unavailable
The AP 7532 802.11ac access point adds bandwidth and performance to your network - a must for supporting high-density traffic from laptops, tablets, smartphones and other devices - while delivering advanced security options. Configure the AP 7532 to act as an in-line sensor for client location awareness and as a tool for security threat analysis, or dedicate a single unit to a security role full-time for greater power and performance. This is the type of flexibility network managers will appreciate when designing your secure network.
Extreme Networks AP 7532 - radio access point
Radio access point
External
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
16.5 cm x 18 cm x 4.1 cm
820 g
Radio access point
16.5 cm
18 cm
4.1 cm
820 g
Europe
External
Wireless
Data Transfer Rate
1.9 Gbps
Line Coding Format
256 QAM
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
PPPoE, BOOTP
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link activity
Firewall protection, routing, auto-sensing per device, DHCP support, power over Ethernet (PoE), VPN support, BOOTP support, load balancing, Stateful Packet Inspection (SPI), dynamic DNS server, DiffServ support, IP address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), roaming function, DHCP server, LLDP support, 3T3R MIMO technology, Low Density Parity Check (LDPC), Space Time Blocking Code (STBC), ceiling mountable, Type of Service (ToS)
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 801.1p, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
3
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 3 x aerial - RP-SMA , 1 x management - RJ-45
UL, cUL, UL 2043, RoHS, EN 60950-1, TELEC, cUL No.60950-1
PoE
OS Provided
WiNG 5
-20 °C
Scroll to top
