BT.com
Wishlist
Mophie Powerstation Plus - Universal External Battery
Mophie Powerstation Plus -...
£69.48
20 in stock
£69.48
Add to wishlist
Delivery
Standard 3-5 working days
Never carry a charging cable again. The mophie powerstation plus universal battery combines a compact design, premium feel and built-in switch-tip charging cable that charges both Apple and micro USB devices. This 6,000mAh battery gives you more than two additional charges on your smartphone or will keep your tablet charged longer for more reading. A second USB port lets you charge two devices at the same time. Charging on-the-go is now easier than ever.
mophie products go through rigorous testing. Each battery is tested three times to ensure peak performance and safe operation. This is the reason why mophie is the #1 and most trusted brand in portable power.
mophie Powerstation Plus - power bank
Power bank
6.85 cm x 13.37 cm x 1.36 cm
160.2 g
Output Connector Type
USB - on cable: Micro-USB, Lightning
6000 mAh
Cables
Micro-USB cable - 22.9 cm , Lightning to micro-USB adapter
2 years warranty
Power bank
6.85 cm
13.37 cm
1.36 cm
160.2 g
Enclosure Colour
Space grey
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B, Lightning
Max Electric Current
2.1 A
LED indicator
6000 mAh
Battery level indicator
Scroll to top
