BT.com
Wishlist
Mophie Juice Pack Plus for iPhone6/6s (3300 mAh) - Black
Delivery
Standard Due date unavailable
Need even more battery power for your iPhone? The Mophie Juice Pack Plus extends the battery life of your iPhone for hours! The Juice Pack Plus also provides a comfortable ergonomic design with the complete protection of a dual-injected hard shell case with protective rubberized band.
The Juice Pack Plus for iPhone combines rechargeable external battery power concealed inside of a protective form-fitting case. It offers the full protection of a hard-shell case with an ultra-thin, light-weight, low-profile design and shock-resistant band.
Features a simple toggle switch allows for standby and charging mode so you only have to use the Juice Pack Plus battery when you need it! Charge and sync your iPhone to iTunes without removing it from the Juice Pack Plus by using the included USB cable. The integrated LED status indicator on the bottom tells you exactly how much "juice" is left at the push of a button. It also indicates the charging status so you know before you go.
mophie Juice Pack Plus - external battery pack Li-pol
External battery pack
7.44 cm x 1.68 cm x 15.6 cm
111 g
Output Connector Type
Lightning - on cable: Micro-USB
Lithium polymer 3300 mAh
Cables
Micro-USB cable
1 year warranty
Apple iPhone 6
7.44 cm
1.68 cm
15.6 cm
111 g
Enclosure Colour
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
Apple Lightning
Detachable Cable Connector Type
Micro-USB Type B
Lithium polymer
3300 mAh
Max Recharge Cycles
500
Power level indicator button, protective case design, impact-resistant, camera lens cutout, battery level indicator
Headphone adapter
Micro-USB cable
Limited warranty - 1 year
Apple iPhone 6
Scroll to top
