BT.com
Wishlist
Monarch LapCabby Mini 20V - 20 Port Mini Laptop Trolley Vertical
Monarch LapCabby Mini 20V - 20 Port...
£861.18
£861.18
Add to wishlist
Delivery
Standard Due date unavailable
Our smaller mobile computer cabinets designed to effectively store up to 20 mini laptops/netbooks:
- All our standard netbook storage features
- 20 bay vertical storage laptop trolley
- Lockable unit to store and recharge laptops -- power supply included
- Laptop trolley delivered fully assembled
- Houses laptops up to a maximum of 10".
All our new mini range of laptop trolleys are designed specifically to house between 20 and 32 mini laptops or netbooks. They come with...
- Storage boxes that hold two netbooks per box and protect your computers from damage
- Power7 Timer -- energy management system fitted as standard -- allowing for Economy 7 charging, daytime charging and seven different charging schedules to be programmed at once
- Individual sliding trays for easy access to netbooks
- For added safety, AC adaptors and power supply are stored in a separate compartment -- only accessible via a concealed door release
- An innovative cable storage system that keeps cables compact, neat and tidy
- Heavy duty wheels with locking facility for easy mobility and storage
- Soft rubber corners to protect your classroom
- Dual point locking system with the key located on the top of the unit to avoid damaging it when the LapCabby is moved
- Houses netbooks up to a maximum of 10".
Dimensions for the Mini 20v laptop trolleys:
Unit - 703 mm x 616 mm x 1115 mm (DxWxH)
Compartment: - 465 mm x 44 mm x 342 mm (DxWxH)
Scroll to top
