BT.com
Wishlist
Mitsubishi Electric Lamp Module For XL550LP Projectors
Mitsubishi Electric Lamp Module For...
£313.84
£313.84
Add to wishlist
Delivery
Standard Due date unavailable
Mitsubishi projectors are equipped with a high-pressure, high-voltage mercury lamp. As a result, there may be times that the projector causes "electrical" shock "when touched", a loud noise is emitted if the lamp burns out or the lamp "temporarily" turns off during operation. The differences between these conditions (lamp burning out or "temporarily" turning off) are significant.
Mitsubishi VLT-XL550LP - projector lamp
Projector lamp
Mitsubishi XL550U
Projector lamp
Mitsubishi XL550U
Scroll to top
