BT.com
Wishlist
Microsoft Wireless Mouse 1000 Mac/Win USB Port
Delivery
Standard Due date unavailable
Reach for wireless comfort and reliability Just plug in and go: This mouse's wireless 2.4 GHz signal and optical sensor let you work confidently and comfortably at home or in the office.
Comfort Comfort for right or left hand.
2.4 GHz Reliable wireless connection with up to 15-foot range.
Snap-in Transceiver Turns the mouse on and off.
Microsoft® Optical Technology 1000 dpi provides responsive cursor control.
Scroll Wheel Move through your documents quickly.
2 Year Warranty Requires a PC that meets the requirements for and has installed one of these operating systems: Windows® 7, Windows Vista®, Windows XP® (excluding Windows XP 64-bit)
USB only 2 AA Alkaline Batteries required (included)
Microsoft Wireless Mouse 1000 - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
5.8 cm x 11.3 cm x 4 cm
67 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, on/off power switch
2 x AA type
Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.4.x - 10.6.x, Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
2 years warranty
Mouse
Wireless Receiver
Orientation
5.8 cm
11.3 cm
4 cm
67 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 5 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
Medical Grade, UL, VCCI, BSMI, ISO 9001, GOST, cUL, ICES-003, ISO 14001, WHQL, CB, RSS-210, EMC, FCC Part 15, IC, R&TTE, KCC, WEEE, ACA, ANATEL, TELEC
AA type
Alkaline
Installed Qty
2
Run Time (Up To)
6 months
5 - 80%
Scroll to top
