BT.com
Wishlist
Microsoft Wireless Mobile Mouse 3500 - optical - 3 button(s) - 2.4 GHz - USB wireless receiver - lochness grey
Microsoft Wireless Mobile Mouse...
£19.27
More than 50 in stock
£19.27
Add to wishlist
Delivery
Standard 3-5 working days
Keep moving with a transceiver that stays in your mobile PC when you go and a mouse that works on more surfaces with Microsoft BlueTrack technology!
  • BlueTrack™ Technology
  • Plug-And-Go Nano Transceiver
  • 8-Month Battery Life
  • On/off Switch
  • Ambidextrous design
Microsoft Wireless Mobile Mouse 3500 - mouse - 2.4 GHz - lochness grey
Mouse
Wireless - 2.4 GHz
Lochness grey
Orientation
Right and left-handed
5.7 cm x 9.5 cm
Wireless Receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Rubber side grips, battery indicator, on/off power switch, Microsoft BlueTrack Technology
1 x AA type
Microsoft Windows 7, Windows 8, Microsoft Windows RT, Windows 8.1
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Wireless Receiver
Orientation
5.7 cm
9.5 cm
Lochness grey
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
Plug and Play
AA type
Alkaline
Installed Qty
1
Run Time (Up To)
8 months
Additional Requirements
USB port
Limited warranty - 3 years
Scroll to top
