BT.com
Wishlist
Microsoft Wired Keyboard 600 Black
£10.48
More than 50 in stock
£10.48
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
This keyboard combines a spill-resistant keyboard with all the features you need - and more - with Microsoft quality and reliability. Enjoy plug-and-play setup and quiet touch keys with quick access to media controls and calculator.
Microsoft Wired Keyboard 600 - keyboard - English - United Kingdom
Keyboard
USB
Layout
Hot Keys Function
Multimedia, calculator, volume, mute
Spillproof
45.6 cm x 16 cm
Microsoft Certification
Compatible with Windows 7
Keyboard
USB
Input Device
Hot Keys Function
Layout
Spillproof
45.6 cm
16 cm
1 x USB cable
Microsoft Windows XP SP2, Microsoft Windows Vista, Apple MacOS X 10.2 - 10.5
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great keyboard
Reviewed by I Humphrey on 23/05/2009
I just bought this keyboard as a replacement for my old clunky keyboard and it is a big improvement. The build quality is very good, the key action is light and quiet, the media centre keys are useful if you listen to music or watch videos and the calculator shortcut key is also handy. It is a very slim keyboard so it fits easily on my pull out keyboard shelf. Highly recommended.
3* Avoid if you use the function keys!
Reviewed by Dan on 23/08/2009
Reasonably solid, nice key action and I dare so quite hard-wearing. The problem I have with this keyboard is it's too compact, the function keys are tiny and it doesn't really feel like a proper keyboard. The is no wrist support so you really need one of those horribly unhygienic gel things. Great if you're short of desktop space I guess, but not recommended for prolonged use. MS make far better keyboards than this.
3* unusual key sizes
Reviewed by Anonymous on 19/09/2011
Considering its such a basic keyboard its not very cheap. The keys don't go down very far which some people might like but I don't. The function keys are small, so that's fine if you never use them, but useless if you do. It has volume control buttons and a calculator button.
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use
Ref: 5GCQ 036864
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£5.74
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
