BT.com
Wishlist
Microsoft Wired Desktop 600 Black
£17.07
More than 50 in stock
£17.07
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
This desktop set combines a spill-resistant keyboard and optical mouse to deliver all the features you need-and more-with Microsoft quality and reliability. Enjoy plug-and-play setup, Windows Vista integration, Quiet Touch keys with quick access to media controls and calculator, and a comfortable ambidextrous mouse.
Mouse Features:
  • Windows Start Button: Press to launch your Start menu and search your PC or the Web if you have Windows Vista installed
  • Plug and Play: No software needed. Just connect the keyboard to your PC and go!
  • Comfort for Either Hand: Use your mouse with your left or right hand--ambidextrous design makes it comfortable either way
  • Optical Technology: Navigate with better speed, accuracy and reliability--the optical sensor tracks movement on nearly any surface without the hassle of clogged mouse parts
  • Scroll Wheel: Move through your documents quickly without having to click on the on-screen scroll bar
Keyboard Features:
  • Media Center: Four hot keys let you control the most-used media activities (play/pause, volume up, volume down, and mute)
  • Quiet-touch Keys: Quiet, responsive, thin-profile keys
  • Calculator Hot Key: With the touch of the button, you can quickly access the Calculator
  • Spill-Resistant Design: Enjoy a drink while you work--this keyboard is designed to withstand an accidental spill
  • Warranty: 3-Year Limited Hardware Warranty
Microsoft Wired Desktop 600 - keyboard and mouse set - English - United Kingdom
Keyboard and mouse set
USB
Input Device
Keyboard
Layout
Hot Keys Function
Multimedia, calculator, volume, mute
Spillproof
Pointing Device
Mouse - optical
USB
Dimensions (WxDxH) / Weight
Keyboard: 45.6 cm x 16 cm x 4.27 cm / 595 g , Mouse: 5.79 cm x 11.3 cm x 3.92 cm / 92.8 g
Input Device
Keyboard
Keyboard Name
Microsoft Wired Keyboard 600
Hot Keys Function
Layout
Spillproof
Pointing Device
Mouse
Pointing Device Name
Microsoft Basic Optical Mouse v2.0
Movement Detection Technology
Optical
2 x USB cable
Windows 8.1, Android 3.2 (Honeycomb) or later, Microsoft Windows 7 / 8 / RT, Microsoft Windows RT 8.1, Apple MacOS X 10.7 - 10.9
5 - 80% (non-condensing)
Scroll to top
