BT.com
Wishlist
Microsoft Wedge Mobile Keyboard - Bluetooth
Delivery
Standard Due date unavailable
A perfectly portable companion for your tablet
The new, ultra-slim Wedge Mobile Keyboard was designed for Windows 7 and Windows 8 tablet users who are constantly on the go. (It also works with iPad and Android devices.) Its thin, lightweight design makes it easy to carry, while the full-sized, soft-touch keyset provides a comfortable, efficient typing experience that makes creating long emails and documents a breeze.
An ideal balance of form and function
The Wedge Mobile Keyboard has a minimalistic yet thoughtful design that gives you exactly what you need and nothing more. The durable keyboard cover not only protects your device from scratches, but also quickly converts into a tablet stand, allowing you to work or watch movies. When you're done, simply snap the cover back on the keyboard to power it down before you stash it in your bag or backpack. It's as portable--and easy--as that.
We also built in some of the most useful commonly used features, such as Windows 8 hotkeys, to give you a quick and convenient way to search, switch between windows, and more. The keyboard also has built-in media keys, making it easy to control music and videos.
Bluetooth® technology eliminates cable and transceiver
Wedge Mobile Keyboard uses Bluetooth technology, allowing you to wirelessly connect to your tablet without a cable or transceiver. For the ultimate clutter-free mobile workstation, combine the Wedge Mobile Keyboard with the Wedge Mobile Mouse.
Microsoft Wedge Mobile Keyboard - keyboard - English - United Kingdom
Keyboard
Bluetooth
Layout
Keys Qty
105
Hot Keys Function
Volume, play/pause, previous track, next track
25.7 cm x 10.1 cm x 2.08 cm
236 g
3 years warranty
Keyboard
Bluetooth
Max Operating Distance
Up to 5 m
Input Device
Keys Qty
105
Hot Keys Function
Layout
25.7 cm
10.1 cm
2.08 cm
236 g
Protective cover
UL, ISO 9001, cUL, ISO 14001, WHQL, CB, RSS-210, EMC, MIC, FCC, R&TTE, NTRA, WEEE, ANATEL, CMII, TELEC, China EIP
Microsoft Windows 7, Android, Windows 8, Apple iOS, Apple MacOS X 10.6 - 10.7, Microsoft Windows RT
AAA type
Installed Qty
2
Required Qty
2
Alkaline
Limited warranty - 3 years
5 - 80% (non-condensing)
Scroll to top
