BT.com
Wishlist
Microsoft Surface Book - i5/256GB & Surface Dock Bundle
Microsoft Surface Book - i5/256GB &...
£1,950.45
23 in stock
£1,950.45
Add to wishlist
Delivery
Standard 1-3 working days
This is a bundle. It contains: Microsoft Surface Book Bundle & Microsoft Surface Dock.
Surface Book
Surface Book transforms into three different configurations, adapting to the way that you work and the places where you create. Surface Book is a powerful laptop with a full sized, backlit keyboard for fast and natural typing.
The 13.5" PixelSense display detaches easily from the keyboard to become a thin, light tablet that works perfectly with OneNote and Surface Pen. Turn the screen around and reattach it to use Surface Book like a creative canvas. By reconnecting it to the keyboard, you unlock its full creative power in a pen first mode.
Use the multi-touch PixelSense screen and Surface Pen to create with all the desktop software you already use, like Adobe Photoshop and Illustrator. Surface Book is the creative professional's laptop, designed to power through professional grade photo and video editing.
Ultimate versatility
Surface Book weighs as little as 1516 grammes and its 13.5-inch PixelSense display has incredible resolution (3000 x 2000). It's calibrated for true-to-life colour, with high contrast and low glare. Detach the screen to use like a clipboard or rotate and reattach the screen to use the Optional NVIDIA GeForce GPU. When you need to connect to other devices and accessories, Surface Book has advanced wireless options and all the ports you need.
Exceptional performance
Surface Book combines the 6th Generation Intel Core i5 and i7 processors and up to 16GB of memory with optional discrete graphics for an unparalleled laptop experience. It's built to handle all of the creative tasks you throw at it. Design, sketch and build without limits. Shoot video and edit in Premiere Pro with amazing fluidity and smoothness. Surface Book handles the most demanding creative tasks without sacrificing battery life. With up to 12 hours of battery life1, it's the ultimate laptop to power your ideas.
Runs Windows & Office perfectly
Whether you're using touch, a Surface Pen, mouse or keyboard, Surface Book runs Windows 10 Pro flawlessly. Create, edit, and share documents in Microsoft Office. Also, Surface Book runs all of the professional-grade software you need, including Adobe Creative Cloud, Citrix, AutoCAD or Visual Studio.
Microsoft advanced technology
Writing with Surface Pen feels as fluid and precise as a ballpoint pen on paper. With one click of Surface Pen, a blank OneNote page appears for quick notes—even if your Surface is asleep. Click and hold the top of Surface Pen to activate Cortana2, your truly personal digital assistant. She offers time-, people- and location-based reminders, or even helps you make dinner bookings. Surface Book is built with the very latest facial recognition camera to make your life easier. With Windows Hello, Surface Book knows you’re you, and will sign you in with no password required.
Business ready
Surface Book can handle any task, while seamlessly pairing with your existing IT infrastructure. Built with a TPM (Trusted Platform Module) chip for security, your device is protected by enterprise level encryption. You can also use BitLocker, new Enterprise Data Protection, Trusted Boot and Windows Defender for malware protection and data privacy. IT can set up Surface like other PCs, by joining it to a domain and managing it using tools already in place like Active Directory, SCCM and Air Watch.
Get right to work
Instantly transform your Surface into a desktop PC. Plug in the Surface Connect cable to charge your device and access external monitors, keyboard, mouse, and more. Find the perfect viewing angle, or position your device to take advantage of the robust pen capabilities.
All the ports you need
With two high-definition video ports, a Gigabit Ethernet port, four high-speed USB 3.0 ports, and an audio output, you’ve got all the connections you need in a sleek, compact design.
Lightning fast with minimalist design
Surface Dock uses Surface Connect technology which enables high-speed transfer of video, audio, and data over a single cable, keeping your desk clutter-free. It also has a Gigabit Ethernet port giving you a fast, reliable connection to your network.
Easy setup
Surface Dock is quick and easy to set up. Connect your peripherals to Surface Dock and then attach the magnetic Surface Connect cable to your device. It’s that easy.
Microsoft Surface Book - 13.5" - Core i5 6300U - 8 GB RAM - 256 GB SSD - English - United Kingdom - with Surface Dock
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit
Intel Core i5 (6th Gen) 6300U / 2.4 GHz (3 GHz) / 3 MB Cache
8 GB LPDDR3
Storage
256 GB SSD
Display
13.5" touchscreen 3000 x 2000
Graphics
NVIDIA GeForce 940M - 1 GB GDDR5
Input Device
Detachable keyboard, Surface Pen
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
Up to 12 hours
Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM) Security Chip, Windows Hello
Silver
31.23 cm x 23.21 cm x 2.28 cm
1.576 kg
United Kingdom, Ireland
1 year warranty
Bundled with
Surface Dock
Operating System
Windows 10 Pro 64-bit Edition
Bundled with
Surface Dock
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
8 GB
LPDDR3 SDRAM
Storage
Main Storage
256 GB SSD
Display
13.5"
Touchscreen
Yes (10-point multi-touch)
Resolution
3000 x 2000
Widescreen
Image Aspect Ratio
3:2
PixelSense
Audio & Video
Graphics Processor
NVIDIA GeForce 940M - 1 GB GDDR5 SDRAM
Camera
Yes - 1080p
Resolution
8 Megapixel (rear), 5 Megapixel (front)
Sound
Stereo speakers, two microphones
Input
Keyboard Layout
Communications
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Run Time
Up to 12 hours
Connections & Expansion
2 x USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , 2 x SurfaceConnect
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Microsoft Office (30 days trial)
Silver
Case Material
Magnesium alloy
Integrated Options
Dockable
Security
Keyboard
Localization
1.576 kg
Limited warranty - 1 year
Office Software - Software applications
Microsoft Surface Book - i5/256GB & Surface Dock...
£1,950.45
Office 365 Bundle
Save £9.99
£2,143.25
Security Software - Protect your system form virus attack
£1,950.45
Protect your Purchase!
Save £30.00
£1,960.44
Scroll to top
