BT.com
Wishlist
Microsoft Sculpt Touch Mouse - optical - 3 buttons - wireless - Bluetooth - storm grey
Microsoft Sculpt Touch Mouse -...
£35.44
5 in stock
£35.44
Add to wishlist
Delivery
Standard 3-5 working days
Looking for a portable mouse that helps you get things done? Sculpt Touch Mouse saves time in long documents and works virtually anywhere, with no cables or transceivers to connect. And it's designed to fit comfortably in either hand.
The four-way touch scrolling pad on the Sculpt Touch Mouse lets you breeze up and down, left and right, and through windows and documents with just the swipe of your finger. While you scroll, you'll feel the nice surprise of tactile feedback.
Microsoft Sculpt Touch Mouse - mouse - Bluetooth - storm grey
Mouse
Wireless - Bluetooth
Storm grey
Orientation
Right and left-handed
6.5 cm x 9.55 cm x 3.3 cm
111 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
8000 fps
Programmable buttons, touch-sensitive scroll, Microsoft BlueTrack Technology
2 x AAA type
Microsoft Windows 7, Windows 8, Apple MacOS X 10.6 - 10.7
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Orientation
6.5 cm
9.55 cm
3.3 cm
111 g
Storm grey
Input Device
Wireless
Bluetooth
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
8000 fps
AAA type
Alkaline
Installed Qty
2
Run Time (Up To)
9 months
Limited warranty - 3 years
5 - 80% (non-condensing)
Scroll to top
