BT.com
Wishlist
Microsoft Sculpt Comfort Mouse - optical - 3 button - wireless - Bluetooth - black
Microsoft Sculpt Comfort Mouse -...
£25.77
Designed for comfort and function, plus stay connected on the go
£25.77
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Access your favorite Windows features—faster and easier
The Sculpt Comfort Mouse, with the blue Windows touch tab, lets you access Windows apps and the Start screen quickly and easily. Designed for comfort and function, it works with most Android tablets on virtually any surface.
The ultimate Windows mouse
The blue Windows touch tab on Sculpt Comfort Mouse revolutionizes the relationship between hardware and software, providing quick and easy access to your favorite Windows 8 features. Quickly navigate to the Start screen and access apps faster. Press the center of the sleek blue tab to switch between your current app and the Start screen. Or simply swipe up on the tab to cycle through all of your open apps, or down to reveal all the open apps and select the one you want.
Bring order to your busy days
The ease and speed of the Windows touch tab means you can get things done with precision and effortless control. Plus, Sculpt Comfort Mouse's intuitive, modern design and high functionality make it the perfect complement to your Windows 8 experience.
Stay connected on the go
Sculpt Comfort Mouse features Bluetooth connectivity, so you can easily pair your device with your PC or tablet and not worry about using cords or transceivers. As well, its BlueTrack technology works on virtually any surface. The right-handed thumb scoop design and Tilt wheel allow you to quickly and comfortably scroll left, right, up and down.
Scooped Right Thumb for Comfort Grip
Ergonomic design for right-handed users makes extended use more comfortable.
Four-Way Scrolling
Scroll four ways for greater efficiency and comfort by using the tilt wheel.
Compatibility
Windows 7
Windows 8
Windows RT
iOS 4
iOS 5
Android 3.2 & above
Microsoft Sculpt Comfort Mouse - mouse - Bluetooth - black
Mouse
Wireless - Bluetooth
Orientation
Right-handed
6.85 cm x 11.1 cm x 3.65 cm
136 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 ppi
Performance
8000 fps, up to 72 inches per second
Scrolling wheel (4-way), Microsoft BlueTrack Technology
2 x AA type
Microsoft Windows 7, Windows 8, Microsoft Windows RT, Apple MacOS X 10.6 - 10.8
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Orientation
Right-handed
6.85 cm
11.1 cm
3.65 cm
136 g
Input Device
Wireless
Bluetooth
Max Operating Distance
Up to 5 m
Optical
Buttons Qty
3
Movement Resolution
1000 ppi
Performance
UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, CB, RSS-210, EMC, MIC, FCC, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO, China EIP
AA type
Alkaline
Installed Qty
2
Run Time (Up To)
10 months
Limited warranty - 3 years
5 - 80% (non-condensing)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* Microsoft Sculpt Comfort Mouse
Reviewed by Angela on 07/10/2014
Mouse keeps disappearing from screen. Have to switch computer off to get it back or plug in another mouse. Would not recommend.
Scroll to top
