BT.com
Wishlist
Microlab T1 Headphones White Bluetooth 4.0 with Phone Function
10 Hours Playback and USB Charge & Play!
Delivery
Standard 3-5 working days
Incorporating the latest Bluetooth® wireless technology, this headset lets you connect to your mobile phone or media player without cables. Using A2DP profile, it lets you listen to stereo music by connecting to any Bluetooth®wireless technnology enabled products.
Designed with beautiful finishes, this headset system is ideal for your personal entertainment. Ideal for digital moview, TV, PC/notebook, CD/DVD and multimedia application.
With its built-in microphone, this system functions as an headset for your video conferencing and communication application.
Comes with rechargeable battery for longer lasting use, and easy charging via USB interface. Includes additional 3.5 mm stereo jack for traditional analog audio input.
Features:
  • Bluetooth® wireless music transfer lets you play from your mobile and any Bluetooth® product with Bluetooth® headset protocol
  • Bluetooth® 4.0 with HFP 1.6 A2DP 1.2 and AVRCP 1.4
  • Bluetooth® stereo audio using A2DP for wireless music streaming
  • Quality headset with depth and full range audio performance
  • CD sound quality with aptX function
  • Clear sound with strong bass
  • USB charge and play function
  • 10 m wireless operating radius
  • Built-in noise reduction function
  • Microphone/answering phone call
  • 3.5 mm stereo jack
  • Quality ear-cups for comfortable wear
Technical Specifications
Amplifier specs
Frequency response: 60-20 000, Hz
Signal/Noise ratio: 85, dB
Speakers specs
Material: plastic
Interfaces: Input micro-USB, 3.5 mm stereo jack
Others: Bluetooth®
Version: Bluetooth® V4.0
Profile: HFP 1.6, A2DP 1.2
RF Range: 10 m
Sound: aptX
Playback time: 10 hours
Charging time: 2 hours (6 hour for initial charge)
Standby time: 30 days
Microlab T1 - headset
Headset - wireless - Bluetooth
Recommended Use
TV, portable electronics, computer
Headphones Form Factor
Full size
Foldable
Wireless - Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 60 - 20000 Hz
Impedance
42 Ohm
Signal-To-Noise Ratio
85 dB
Microphone
Built-in
Controls
Volume, answer/end, play/pause
Headset - Bluetooth
18 cm
18 cm
Body Material
Plastic
Earpad Material
Soft leather
Recommended Use
Headphones
Circumaural
Headphones Cup Type
Closed
Foldable
Dynamic
Available Microphone
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
60 - 20000 Hz
85 dB
Total Harmonic Distortion (THD)
1%
Impedance
42 Ohm
Diaphragm
50 mm
Remote Control
Controls
Wireless Link
Transmission Range
10 m
Connector Type
Headset (mini-phone stereo 3.5 mm) , USB (5 pin Micro-USB Type B)
USB charge cable , Headset cable
Headset battery rechargeable
Run Time (Up To)
10 hour(s)
Standby Time
720 hours
Recharge Time
2 hour(s)
Scroll to top
